The EPA 'highway' test has a max speed of 60 and an average speed of 48.3. That is not fast at all. If you drive like that you will definitely get the EPA rated range.
The EPA "high speed" test has a good section of driving at around 70 mph but there is also a section in the test cycle of low speed which evens out the average speed to 48 again. I'm not sure what they thought that test would achieve.
EPA tests vehicles by running them through a series of driving routines, or schedules, that specify vehicle speed for each point in time during the laboratory tests.
www.fueleconomy.gov
But let's look at some real world data. Here are some longer drives I did recently. I picked longer drives (close to 100 miles) and there is almost no net elevation change. There are some hills so there is some up and down like there is no most roads.
I am comfortably able to get rated range on some of those driven even going faster than the EPA test. These drives were not done to be efficient on purpose. It's just whatever the traffic would allowed on that day/time. When the road was open I was always 10 above the speed limit. 100% efficiency means 'rated range'. Climate control was on auto. Since my tires are 3% larger than original, those numbers would actually be better by 3% but I didn't bother to convert them.
