I call BS. My typical has never changed from 200 Wh/km. I believe it is tailored to the specific configuration but not driving history.
DITB, even with a constant "typical" Wh/km rating, there will be varying AC consumption depending on the efficiency of the charger at that particular line voltage, battery voltage, and current. My lifetime average is 208 Wh/km (driving, not charging).
Well, Steve, despite not knowing your life time average, I was quite close with my 212 guess, which I "reverse engineered" from your numbers.
(EDIT: It was late last night, now I don't know how I got to that number, 212)
It's very easy to find out, whether "typical range" is affected by driving style, or not.
1. While charging, note the combined amps and voltage, to find the precise kW of charging, ie (32+32+32) x 238 = 22,848 W or 22.848 kW
2. Select "Distance" and "Typical range" in the units screen under settings
3. Let the charging stabilise, like one hour charging or more, but before it starts to taper
4. Divide the kW from 1 with the indicated (and stabilised) km/h charging, ie 22,848 W / 104 km/h, to get
219.7 Wh/km
So now I don't know where I got the 212 Wh/km guess from, although it was close to your 208 Wh/km
Still, my 222 is higher than your 220. Could be fluctuating voltage, or the initial charging not increasing equally fast?
The car measures how many kW is being charged, then (if distance is selected), converts it into km/h in either RATED or TYPICAL. While the kW rating is near instantaneous, the km/h is average from charging started (hence one has to wait a while for it to stabilise). I would presume the car simply takes kWh charged over the time of the charge, then divide by the rated or typical Wh/km. ie charging 19 kWh over 52 minutes would give (19.9 * 60 / 52) / .2197 = 104.5 km/h
The question still remains:
When the car displays how fast you are charging, and you selected "Range" and "Typical", converting kW measured (or kWh/h since it's an average not instant) -
is that conversion affected by your driving history?
Put in another way:
Two identical cars, on the same charger, one having a very gently driving history while the other always driven like a race car: Will their km/h charging show the same or not?
