It is not over until over. Shall see
I'm so jealous reading all the positive experiences people have on this forum with solar and ESS; lucky bastards.
tryingThink of it as you being the squadron leader clearing the way for the rest of us.
yea i think you were def the FNG that had point on this oneI feel like I'm more of the FNG that was told to run through the minefield to clear a way......
Others here have talked about the 7 day discharge report that PG&E requires for SGIP. I read about it before it was required.They could not get the data, so I just called Tesla asking for their SGIP group to pull the info from my batteries and send me the file.
We should have known this was needed, oh well.
Weird. That isn't what we had to do. We had to get PG&E sign off before the build as part of the permitting process.I have permit for adding 15K more solar, 41 panels, to bring total to 29KW, 88 panels. Waiting for installer to set install date.
Then told ONLY after installed do they send info to PGE asking for approval.
i have told them. they told they have had to remove dome in past at their cost.Weird. That isn't what we had to do. We had to get PG&E sign off before the build as part of the permitting process.
If PG&E says "no" post build, the homeowner would have some expensive shingles, wouldn't they? What is the next step if the utility says "no more than 40W-minutes per year of solar at this address"?
I realize you are in a different area, with different permitting regulations, but it seems like build first and get approval later has the potential to strand a large cost with no recourse.
Good luck.
BG
I was surprised also when I found out no pre-authorization happens. When the installers came out, said yeah, its all approved by PG&E... Then later while talking to the Tesla rep, she specifically said no. I asked, "What happens if PG&E does not approve", her response was "We come pull off enough panels to get PG&E approval"... This sounds like a really backwards way of doing things. I have some concern since the system is about 160% of last year's usage. We did purchase an EV, so that helps, but even after that we are 120-130%. I am waiting for PTO, and still have not seen one single interconnection document of any type... Tesla never once mentioned size might be a problem, and they have my previous year's usage.i have told them. they told they have had to remove dome in past at their cost.
Livin' on the edge!Just got a call from my installer that they are coming tomorrow, 2 days, to install 15K more solar on top of the 15K I already have. What will PGE say? No idea
