You can think of it this way: your normal house wall outlets can source 15 or 20 amps, but your phone charger draws less than one.I am looking to add a 50 amp circuit for my mobile charger. Tesla says that a 14-50 plug charges at 32 amp but the connecting plug says 30 amp rating. Is this safe?
thank you for your quick reply. However, my question is, is it safe for the wiring of the plug since it is rated at 30 amp and could possibly be drawing 32 ampWhile I have 60amp circuit for Tesla Wall Charger at home, I use 14-50 plugs with mobile charger in different places and it charges with 32amps with no issues.
If I wouldn't be a geek "I need the fastest charging I can get" and electrical engineer, I would go with installing 14-50 plug and using Mobile Charger. 32amps still charge Model Y to 80% overnight, so no real difference in outcomes. Way cheaper to install and you reuse existing mobile charger that you already have.
NEC limit for continuous use is 80% of circuit breaker capacity. 60 amp circuit will give you 48amps for charging, and NEMA 14-50 plug can give you 40 amps in theory. 32 amps is a limit of Tesla Mobile Charger itself. You can buy (or get almost for free from the utility company) a wall charger that plugs into 14-50 plug and you will get 40 amps out of it.
Not just possibly - it will be drawing 32 amps for hours and hours of charge unless you specifically reduce it to 30 amps in the app. While I think your concern is reasonable and I also don't understand why Tesla decided to put 30amp-rated plug into 14-50 adapter, they've designed the whole chain adapter-charger-app-car to work at 32amps and I wouldn't be worried about it.thank you for your quick reply. However, my question is, is it safe for the wiring of the plug since it is rated at 30 amp and could possibly be drawing 32 amp
It's a strange thing, but no one has had issues due to it. Labeling was originally 32A.thank you for your quick reply. However, my question is, is it safe for the wiring of the plug since it is rated at 30 amp and could possibly be drawing 32 amp
The plug has a sensor (probably a resistor) in it to tell the mobile connector the max amperage it can pull. The Mobile connector will then tell the car that’s the max it can pull.thank you for your quick reply. However, my question is, is it safe for the wiring of the plug since it is rated at 30 amp and could possibly be drawing 32 amp
Yeah, as @davewill mentioned, this showed up several years ago and confused a lot of people. It is designed and built and fully intended to operate at 32A. We never got any answer from Tesla as to why they printed that "30A" on the adapters. It's not what it actually does. The prevailing theories are that it was because of some obscure +/- margin range of testing policy or something, so it's some kind of bureaucracy thing.thank you for your quick reply. However, my question is, is it safe for the wiring of the plug since it is rated at 30 amp and could possibly be drawing 32 amp
The charging cable and charging connector may feel warm when touched. You would need to use a handheld infrared thermometer to determine how hot. I have measured temperatures of ~115F to 120F where the charging connector/cord meet using a public charging station. One charging station measured consistently warmer at 130F. I contacted the charging equipment provider about my concern about their equipment running warmer than expected. Eventually all 8 of the charging stations were replaced. The 130F temperature has not recurred with the new charging station equipment.Ok I found an electrician who installed a50 Amp circuit. . Now when I charge the car the wire gets hot. Is this normal?
Yes most likely normal unless it's too hot to touch. The charging cable that plugs into the car will get warmest close to connections where there is increased resistance. Mine gets warmest where it enters the mobile charger unit with the green lights. Wouldn't worry. Enjoy the car.Ok I found an electrician who installed a50 Amp circuit. . Now when I charge the car the wire gets hot. Is this normal?
It's normal for it to get quite warm while charging.Ok I found an electrician who installed a50 Amp circuit. . Now when I charge the car the wire gets hot. Is this normal?
While true, there are levels of heat that will cause problems, especially long term, that won't trip that error.It's normal for it to get quite warm while charging.
In the case it should get too hot, there is a temperature sensor built into that Nema 14-50 adapter that will cause the car lower your charge rate from 32 amps to 16 amps and you will see an error on the car telling you so.
For example..
My cable overheats and drops to 16 Amps if my Tesla is set at 32 Amps during summertime when the temperature exceeds 85F or so. Just set your Tesla to charge at 22 to 28 Amps and it will work fine. I drive 130 miles daily, connect my 32 Amp-rated Tesla cable into an outlet fed by a 240 Volt, 50 Amp breaker on a separate electric meter and charge at 22 Amps for about 7 to 8 hours overnight (off-peak charging costs about 1/2 price). You really don't need 32 Amps to charge unless you are in a hurry. If you are really in a hurry, use a supercharger. If you really want to save money, charge at home at 22 to 28 Amps, at 240 Volts.I am looking to add a 50 amp circuit for my mobile charger. Tesla says that a 14-50 plug charges at 32 amp but the connecting plug says 30 amp rating. Is this safe?
Well, no. There are plenty of folks with 2-4 Tesla cars and they need max charge speed.My cable overheats and drops to 16 Amps if my Tesla is set at 32 Amps during summertime when the temperature exceeds 85F or so. Just set your Tesla to charge at 22 to 28 Amps and it will work fine. I drive 130 miles daily, connect my 32 Amp-rated Tesla cable into an outlet fed by a 240 Volt, 50 Amp breaker on a separate electric meter and charge at 22 Amps for about 7 to 8 hours overnight (off-peak charging costs about 1/2 price). You really don't need 32 Amps to charge unless you are in a hurry. If you are really in a hurry, use a supercharger. If you really want to save money, charge at home at 22 to 28 Amps, at 240 Volts.
Something is wrong with your outlet or cable. I would have it checked out.My cable overheats and drops to 16 Amps if my Tesla is set at 32 Amps during summertime when the temperature exceeds 85F or so. Just set your Tesla to charge at 22 to 28 Amps and it will work fine. I drive 130 miles daily, connect my 32 Amp-rated Tesla cable into an outlet fed by a 240 Volt, 50 Amp breaker on a separate electric meter and charge at 22 Amps for about 7 to 8 hours overnight (off-peak charging costs about 1/2 price). You really don't need 32 Amps to charge unless you are in a hurry. If you are really in a hurry, use a supercharger. If you really want to save money, charge at home at 22 to 28 Amps, at 240 Volts.
