Should be around 14 mphI have a 6-20 outlet at my workplace, and was planning on using that to charge. Anyone have an experience with charging using this outlet, and the approximate speeds they have been getting?
310,000 w/ mile!My home setup is 6-20. I start my day @ 80% and end ~60% and it takes ~4 hours to recover.
My commute is less than 35 miles so you would think I'd be charged up in 2 hours. Nope. P3D+ @ ~310 ish lifetime kW/mi
The only problem with that chart is that the entries for 5-15 and 5-20 under Model 3 should be 2 mph higher than they are. For whatever reason, Tesla screwed up those entries.
Yup yup. I was giving a real world example to temper OP's expectations.The problem is you’re using some 1.5 miles of rated range for every mile traveled at that 310 wh/mi efficiency. Then probably running sentry mode all day, which doesn’t factor into your efficiency numbers.
The charger doesn’t care how many miles you’ve driven, only how much energy you used. This is a good demonstration as to why “miles per hour” is really a poor measure for charging.
I'm in the same boat as you; the 6-20 I can use at my workplace generally does a good job of keeping my car at a reasonable state of charge. Depending on the weather, I get from 12-15 rated miles per hour of charge from the 6-20 connection.I have a 6-20 outlet at my workplace, and was planning on using that to charge. Anyone have an experience with charging using this outlet, and the approximate speeds they have been getting?
The voltage actually is up to spec. Most commercial installs have 208v rather than 240v.I'm in the same boat as you; the 6-20 I can use at my workplace generally does a good job of keeping my car at a reasonable state of charge. Depending on the weather, I get from 12-15 rated miles per hour of charge from the 6-20 connection.
I'm in a suboptimal state with it too, as it's only one-phase and throwing 200-203V rather than 220 or 240; I imagine the charge rate would be even better if the voltage were up to spec.
I use a 6-20 as my primary at-home charger (formerly used the outlet for a radial-arm saw). At 239v I get 14-15 mph, which I find more than adequate for charging.
Keep in mind that Tesla rates the M3 at about 240wh/mile, so each Kw give you roughly 4 rated miles.
Simple arithmetic: 239v*15a (the charge rate for a 6-20 outline) for 1 hour is 3.6 Kwh, divided by 240wh gives 14.9 miles/hour. (The actual result is less because of losses in the electronics, etc.)
If your outlet is 208v, then that is 208v*15a/240wh = 13 mph.
