S4WRXTTCS
I keep my eyes on the road at all times and my hands on the wheel. I miss the visual warning EVERY SINGLE TIME because I'm focused on what's happening OUTSIDE the car, not on what's happening in the instrument cluster. My flight instructor used to say that unless you are flying hard IFR you should have your eyes outside the aircraft and glance at the instruments every couple of minutes. That's exactly the way I drive on autopilot. If three audio warnings disable autopilot then it will be absolutely worthless to me. All the audio warning does is to tell me that I'm not applying enough torque to the wheel, my hands are already there. They REALLY need to rethink this.
I'm the same way, and had the same concern because I hardly ever see the visual one. But, then I came across the post describing the visual notification is going to be different. That it's going to flash where it's more prominent. So it's likely not going to be as hard to miss for those of us that barely glance at the IC. Hopefully they'll also adjust the sensitivity of it so it works better for those of us who have a hand at the wheel.
