Charged to 90 percent today. A 90 percent charge has consistently yielded 278 miles since the car was delivered in December. Today it increased to 285. On software 2019.20.2.1, which was downloaded about two weeks ago. What gives?
I recall early software updates on S that appeared to reset rated range variables resulting in temporarily restored range that went back to real values after a few weeks.Charged to 90 percent today. A 90 percent charge has consistently yielded 278 miles since the car was delivered in December. Today it increased to 285. On software 2019.20.2.1, which was downloaded about two weeks ago. What gives?
Or, is your 3 a RWD LR? Tesla announced increase in max range (which we all knew was there anyway) but I haven’t seen it appear in our RWD. Could it be unlocked by this update?
As a former 1st gen leaf owner That had the factory “guess o meter” I can say I am amazed at how accurate it is in my Model 3How does the Guess-O-Meter work on a Tesla? I'm about to buy an M3 AWD in the next couple of weeks, currently I have a Volt. On the Volt the range is calculated dynamically depending on your recent driving history so if you are driving on back roads the range goes way up and that's reflected on the Guess-O-Meter's range estimate, if you are driving on a highway the range goes down and that reflected pretty quickly on the Guess-O-Meter, does the Tesla do something similar or using some other algorithm?
This is just deduction here: 2019.16 reputedly caused incorrectly low display or calculation of rated miles for some owners. Long threads about that. I’ll bet 2019.20 fixed the bug and reset all range calculations to original factory settings. I’ll bet in 3 weeks you’ll be back near where you were.I's a dual motor performance.
Disagree. We do understand the display on Tesla. As noted above by @GWord , it is a constant wh/mi multiplied by remaining battery capacity. Many auto makers' "guess o meters" are complex algorithms that factor in all kinds of crap. Not Tesla's rated miles. The only thing in that formula that can change is Tesla's calculation of remaining battery capacity. There are occasionally bugs in that calculation, and over last 7 years, perhaps 2 or 3 software updates have "fixed" that calculation and thereby reset rated range.I don't think we fully understand the display. Tesla says it's an algorithm so many things can affect it and Tesla can change it maybe even without a software notification. Measuring battery capacity and charge level is very complicated and difficult. In my Ford Fusion Hybrid "distance to empty" display, the mile countdown sometimes differed a lot from the odometer particularly when nearing empty or when driving conditions changed a lot.
On the Model 3 it’s just the amount of energy in the pack divided by the EPA Wh/mi. There is no dynamic GOM in the Tesla.
Actually, there are 3 range projections:There is a dynamic GOM in the car’s energy graph. You can select estimates based on your previous 5, 15 or 30 miles of driving.
I had 4 Leafs over the last 10 years (still have 1), and was the national leader in distance obtained on a single charge for awhile. I agree that the Model 3 range indicator is much more accurate. I have driven my Model 3 down to 1 mile left on range and it was a very precise countown that matched actual driving distance, whereas the Leaf, below about 15 miles of range just stutters and stammers, sometimes saying we still have 8 miles after driving with that number shown for 3 miles, and then going to a flat line symbol. I also have never run out of juice in any EV.As a former 1st gen leaf owner That had the factory “guess o meter” I can say I am amazed at how accurate it is in my Model 3
I drive consistently, in the Leaf I had to really take it easy if I wanted range, the Tesla you don’t it is so fast and efficient.
My leaf said 160km range, best I ever saw highway was 100.
My standard plus is rated 385 km and I have seen 320 km highway with 50 left...AC on at 110km hr
Amazing
