Daniel in SD
(supervised)
Technically I'd be getting less than someone who paid $2k at purchase since my car has 15,000 fewer miles of life left.In what way wouldn't it be the same - the same cost for the same outcome, isn't it?
if and when this update is released, do you guys think there'll be a way to add the cost of the upgrade to the payment on the vehicle?
or will i have to pay the full amount straight up?
I honestly don't recall. I thought at one point there was a $1K difference before or after purchase but could have been the time they were planning a price increase so it never actually worked that way. Found this article but as you state, it may not be accurate.
There was a running scare for many months that if you didn't buy FSD at $6k now with your vehicle purchase and wanted to buy it later the price would be $1000 more. But that only because the overall price of the FSD was speculated to increase. Which it did. Still, the price of FSD during that time was the same if bought before of after vehicle purchase, excluding a down the road price increase.......as it were, not to put too fine a point on it, blah blah, blah.....
Technically I'd be getting less than someone who paid $2k at purchase since my car has 15,000 fewer miles of life left.![]()
Yeah, I think they got rid of that whole pay $X at time of purchase or X+ after and went with language that the price is likely to increase later. I think this is much better because when the said the after-purchase price would be $X+, I took that to mean that for the life of the car I would be able to purchase for the quoted $X+ amount, which has turned out not to be true.There was a running scare for many months that if you didn't buy FSD at $6k now with your vehicle purchase and wanted to buy it later the price would be $1000 more. But that only because the overall price of the FSD was speculated to increase. Which it did. Still, the price of FSD during that time was the same if bought before of after vehicle purchase, excluding a down the road price increase.......as it were, not to put too fine a point on it, blah blah, blah.....
Yes, but the difference isn't that big. If you correct for Tesla's rollout marketing shenanigans, they always kept the delta between the LR AWD and P at around 1s (for example, Motortrend measured the LR AWD at 4s flat w/ rollout). We'll have to wait and see if this "acceleration boost" changes the pecking order.I don't think so. I think someone caught something in the source code early in the leak that said it would only drop the 0-60 time by 0.5s. The P3D does 0-60 in about 3s after the most recent upgrade. The LR+ only does 4.4ish. So this wouldn't get you to full Performance specs.
Perhaps. But it's not obvious how much headroom the P models have left (hardware-wise).So if that's the case then they should offer this option for the P as well to keep the delta inline.
Second, yes, nobody knows the part differences between the 980 and 990. But you can bet they’re different for a reason.
Lastly, Tesla is trying to make money. Selling the update to 3P is not happening for $2k.
This isn't correct- apples to apples the P does about 3 flat now, and the AWD does 3.9.
Tesla deceptively uses 2 different measurements for the 2 cars.
So a .5 second improvement to the AWD would drop it to ~3.4 apples to apples vs 3.0 on the P.
The whole 980 / 990 discussion has been beaten to death.
Biggest difference between a P and an AWD is not in the rear it is in the power to the identical front motors.
So to base anything on that is shaky at best
I think it's very presumptuous to assume there's an actual difference at this point.
Oh god here we go againYes, but the difference isn't that big. If you correct for Tesla's rollout marketing shenanigans, they always kept the delta between the LR AWD and P at around 1s (for example, Motortrend measured the LR AWD at 4s flat w/ rollout). We'll have to wait and see if this "acceleration boost" changes the pecking order.
I knew you would chime in lolThis isn't correct- apples to apples the P does about 3 flat now, and the AWD does 3.9.
You contradict yourself here.
If "only" the 980 can be a P, then selling a full P unlock only to 980 owners (that is, owners from 2018 and early 2019) is nothing but making money and can't hurt future P sales since new AWDs can't do this upgrade.
It's true this is the biggest difference - and we know from Tesla that those front motors are identical so that's just a software limitation. But there is a 30kW or so difference in the peak rear motor output, which is not nothing. Plus there is the difference in maximum torque all the way up (this is not an average power limitation) - and if there is some reason the torque has to be limited in the 990 motor (to be clear, I don't know why there would be such a physical limit due to components), that would be significant (power limitations don't even come into play in acceleration until over 45mph (or ~30mph, if you're comparing points on the P curve to the AWD curve)).
Remember it's the area under the curve that matters, not just the peak.
Credit to @EvanLin for the image (I believe, though I am not sure, that this is taken from a video of CAN bus motor input power data during a 0-60 run, so don't take it as exactly correct):
His Post
This is also circumstantial data, but...
The EPA submitted data from Tesla does say, explicitly, since 2018 (the numbers haven't changed to match the two 5% power bumps):
"20xx MY Model 3 AWD Long Range Carline; AWD & PERF SHARE COMMON FRONT MOTOR - 147 kW; REAR (AWD) - 188 kW; (PERF) - 211 kW;"
The implication of this statement is that the rear motors are different. However, it is not proof. (It is proof that the front motors are identical though.)
Download Fuel Economy Data
I question wether pulling data from the CANBUS tells us anything.
Absolutely true which is why I mentioned the statements to the EPA. Which as I said is just implication at best.
Actually the EPA data says that the LR AWD and the LR Performance all share the exact same motors "147 and 188 kW AC 3-Phase" the 211kW is the RWD models
I updated my post. The EPA data actually implies they're the same
Edit: adding screenshot to save searching
