Mine is like this right now. Everything seems to operate properly, but it appears the rear is too low. The first time I asked about it and pointed out the alignment TSB, I asked them to calibrate it. Their response was that they would check the software to be sure it was calibrated and that they didn't need to measure it. I didn't push the issue at the time, but as an engineer I know enough to know that a simple check of the software is probably not enough to be sure all is well - a measurement must be taken. I asked them to measure it according to the TSB, and they said they did and found it to be OK. I figured I had been enough of a squeaky wheel so I left it alone. But when I measured it myself afterward at home, I found the front ride height to be within 2 mm of spec on the front, and about 25 mm too low in the rear.
I am going in this Friday for a second appointment to fix this. I really, really hope they don't fight me on this. There are few things more frustrating than arguing with a service guy about matters like this.
