Hey folks,
@Daniellane,
@Runt8, and everyone else, I want to go back to an earlier question, which is still not clear to me.
On Tesla's support page,
Wall Connector
it says:
"Higher amperage installations are recommended (but not required) when power sharing to maximize the amount of power split between each car when charging."
So why can't the circuit breaker be set at say 120A on a 150A circuit (if you have the capacity), with two wall connectors? (And set the rotary switch on each wall connector to 48A.) So that each can draw the max 48A, when charging two model 3s at the same time. Would this work?
From what I understand, the intelligent sharing via the master/slave/slave setup is only if you don't have the circuit capacity (say max of 50, 80 or 100A), which most people probably don't (as
@eprosenx and
@Zaxxon pointed out). That way, you can get max charging with single car, but lower speeds if you need to charge more than one car. Also you can take advantage of older Model S,X charge speeds (on say a 100A line).
But (at least as a theoretical exercise) if you only have model 3s or the newer 48A max charging S or Xs, AND also have the capacity for a 150A line (120A breaker), then you can run one shared line or two separate 75A lines (w/ 60A breakers) for two wall connectors (the shared line being cheaper parts and labor wise I would guess). In either scenario, you get the max charge speed. No?
Sorry for all the questions, just trying to understand what the theoretical limits are here.
Thanks!
