"Soon" Still refreshing......Any news on the CCS NA adapter?
We received the CCS adapter from Korea today, and I quickly took a look and put it to the test:
Electrically, it is straight through. No resistance. This is just a dumb mechanical adapter. Which of course is very smart!
It's build solid and heavy, just like Tesla's J1772 adapter. The latch pin feels very strong, I think it's machined steel. Great design.
It does nothing with an older chargeport. Plugging in an AC charger, it negotiates, but will not charge of course because Tesla didn't include AC pins. Missed opportunity I think to start including this stead of the 1772 adapter!
Will be testing with a 2021 3 next week.
We REALLY need to start begging Tesla to offer chargeport ECU upgrades. The part is already available for $150 and easily installed, but service needs to update the car's configuration.
Here's a quick look!
If you have firmware 2021.40.x, or higher, you can look in the vehicle information screen and see if it says "CCS Adapter Support: Enabled" (Or if it says "Not Installed".)How do we know if we need to updated chargeport ECU? Is the LED location a good indicator?
Why not? It would remove the need to buy those rings that go around the J1772 adapter to lock the charging handle to the adapter when the adapter is locked to the car.I've used my J1772 adapter quite a lot - I don't think I'd like to use this instead for that purpose.
Good video review, thanks. Not that I'd be using this adapter very much but I wonder over time if the weight of the cable and connector would damage the charge port - since the CCS adapter, like the Tesla Mobile charger and Supercharger, don't really insert very far into the port.....We received the CCS adapter from Korea today, and I quickly took a look and put it to the test:
They could design a smaller J1772 adapter, based on the design of the CCS, with the same locking pin. I rarely ever use the locking ring (ordered it a while ago but haven't used it except to test it) because I rarely ever charge at J1772 stations and even when I do, it's not something I'm too concerned about. However, I do plan to use it when I park my car at the airport next month.That's a good point, but the J1772 adapter is nice and compact. I've never owned a locking ring for it and it's never been a problem for me. I guess that's a bigger issue in denser populations?
Thanks for your video.. Did you test your CCS adapter? How was your charging speed?Yes, you can view if your car has the CCS-capable board on your info screen.
I would guess it will work fine on S&X as well, I meant the adapter doesn't allow the charger to work if you have an older charge port board.
How hard is it to order this from Korea? I'm getting impatient with Tesla (heh, what else is new?).
Any new test results as well?
