EVer Hopeful
Not everyone charges at night. I charge mine mainly between 10am and 2pm and need a higher speed.
How come?
and (not to get too personal but) what do you do at night?
Haha, no worries. I sleep at nightHow come?
From the very thread you posted:Also some backup on the subject. Is #6 Romex ok on a 60 A breaker
My understanding is if you want a 60a circuit, you either need to go to a larger gauge NM-B (romex) wire or you need to do THHN which has to be in conduit. I believe something like this would be ok - https://www.amazon.com/Wirenco-Aluminum-Armored-Stranded-Conductor/dp/B09317WBJZ?th=1 - but not 100% sure.also any suggestions/links on non-Romex wire that I should purchase? for this second run I'm not going to wrap it around the garage so it'll only be about 50'
That’s exactly what I end up using for my DIY 60A EVSE installs. You can’t just run THHN inside wall studs, it has to be run in conduit. Which means either PVC or metal conduit (both pains to work with), or go the easy route with MC cable as you linked to above. The only downside with MC cable is that it isn’t waterproof, so make sure to only use inside. Also there is slightly unique tradecraft with MC Cable, look up YouTube videos. But overall, it is almost as easy to use as romex, and you get to use 6 gauge rather than 4 gauge (as you would have to with romex).My understanding is if you want a 60a circuit, you either need to go to a larger gauge NM-B (romex) wire or you need to do THHN which has to be in conduit. I believe something like this would be ok - https://www.amazon.com/Wirenco-Aluminum-Armored-Stranded-Conductor/dp/B09317WBJZ?th=1 - but not 100% sure.
Which is why using MC cable is so nice, no need to do that!...don't forget to calculate the number of bends in the conduit and the percentage fill
Have you tried to see if another cable will fit? There doesn’t appear to be any code unless it is more than 2 in a hole that is fire or draft stopped. Also cable spacing between joists must be maintained according to manufacture specifications.last questions for the electricians in the group.
is it ok to run a second 6/3 wire through the same holes in my joists that my current 6/3 wire is in? if this is ok then adding another run of cable will be much easier vs. drilling through a handful of boards.
thanks!
Yes. You are good. That wire is fine (and rated) for that purpose.yes the entire run is in metal conduit. however, I just looked in the basement by the panel and crap it say NM-B.
"encore wire corp 6/3 w/g type nm-b 660v (UL)"
I assume I should switch back to the original 50 amp break or will I be ok?
I just installed my wall charger and used 4/3 wire as I was only going a few feet from my breaker box. The wires are thick as hell and take some serious work to bend/fit into charger wall mount. Now that I've installed one, I'm sure I could do it again in about an hour.
It’s generally up to the local inspector, but, running romex in conduit is ok for short distances where it is sleeved for protection. However, conduit outdoors is considered a wet location and regular romex cannot be used. I believe SER or UF can be used.Hi everyone- I just got my Tesla yay I am planning to run 6/3 romex cable (~70ft) with 5O Amp circuit breaker and limit the wall charger amperage. My electrical panel is at the basement on the opposite side of the garage and I need to run part of the cable outside the building (<10ft). My question is that is it OK to run it inside a conduit when the wire is outdoors? I read conflicting information about if it’s allowed to run Romex cable inside conduit or not. Thanks for the help
