Newbie question: Is -x for regen? I have not been able to pay enough attention the 3 times I've driven my car.
Drive down a mountain.Yep. Almost intuitive, right.
Regarding the power meter...
We should probably start a poll: Tell me what you think the power consumption is for this image?
Model S Autopilot Press Kit | Tesla Motors
One guess...
- it's in the range (0, 75)kW [otherwise the UI is broken, IMO]
- if it's "somewhat like exponential", then it's in the range (0, 37.5)
- because it's orange I'm guessing it's in the range (30, infinity)
I'm going to guess 32 kW. If so, that would put the Wh/mi around 500 in the middle chart. So that's probably wrong.
Solving from 292 ... you get just under 19 kW. I would definitely not have guessed 19 kW from the position of the orange arc.
I've driven Model S since November 2012. It shouldn't be this difficult for a Model S veteran to read the display. Maybe I need more sleep.
Not everyone's obsessed with 5s and 10s. :tongue:
I am, though. It frustrated me the other day when I tried to engage it at 65 and got 64, then did the quick tap up to supposedly get a 1mph increase and it locked to 66mph. :cursing:
Agree, but the location of the circle at the end of that chart is the best check you have against what you think the meter is telling you. No?You can't extrapolate from 292wh/mi average over the last X miles to instantaneous kw usage.
This was described before, but not what I've seen in my car.In AP cars under 6.2, TACC locks on the round 5s when you do full up or full down on the cruise stalk. So rather than +/-5, you get the closest 5. Thus, you could lock at 64 and do a full up to 65.
I'll get there. Hard here at sea level. :biggrin:Drive down a mountain.
2 cars. I've never noticed the "sticky to multiples of 5" behavior in either car.My regular cruise works as traditional - roughly 1 and 5 mph increments. All four TACC cars I've driven work on 1 mph and closest 5 mph increments. Wouldn't your Sig work like mine though, in essence meaning we both are confirming the same scenario?
That's not what I meant by "sticky". "Snap" is probably a better word. I was referring to what Cyclone was talking about here:Mine does. Slight pressure up or down and TACC goes +/-1, hard up or down (almost like a click) and it's "sicky" 5mph
Not really, I've only seen a very small handful, just repeated over and over:True enough, most points have been constructive, but man there are a lot of them!
That's def how it works in MBZ and seems the same in T. Stick even is the same.Mine does. Slight pressure up or down and TACC goes +/-1, hard up or down (almost like a click) and it's "sicky" 5mph
Is this second behavior listed what you experience Max?
