I presume Porsche will design their battery pack and cabling to take advantage of the 800V. 15 minutes to 80% charge on a 400 mile pack would be AWESOME. Basically rivals ICE cars. Tesla needs some competition, it will be good for Tesla loyalists.
As several of us are trying to explain... simply quoting higher voltage #'s as if that automatically guarantees faster charging is not necessarily the case. Remember, it's
current flowing in to the pack that dictates overall charge rate.
@JRP3 and I trying to point this out.
The 85-100kWh Tesla packs are somewhere in the neighborhood of 225-265Ah, with a nominal voltage of ~375V (max 400V). At ~330A charging, they are already pushing a 1.25-1.5C charge rate. And depending on ambient conditions, they are also working overtime to shed heat while charging (car's thermal management system kicks in to high gear).
For a pack of similar capacity but rated at 800V max, the pack's current capacity would be halved, so ~112-132Ah. So at the same C-rates the pack would only be able to safely draw ~165A or so. For those above-mentioned supposed 350kW stations, you are talking ~440A @ 800V... greater than 3.5C as
@JeffK. That implies very large conductors and connectors, a lot of thermal management capacity, and a cell chemistry that may not be well suited for other aspects of automotive applications.
Even charging at the same ~330A capacity as Telsas do today is a ~3C rate. Now the as-of-yet vaporware vehicles could have larger packs (say ~125), but that doesn't change the fundamental issues all that much...
Greater voltages do have some advantages for the same given power, namely smaller conductor sizes. There are also some disadvantages, such as greater insulation required (negating some of that conductor advantage), and the need for higher rated components.
Increasing voltage is not a magic bullet..
