Perry
Then maybe I'll go with 19x9.5 +40. How much inner clearance do you think I'll have?There is. I’m running 18x9.5 +39 and the tightest clearance spot is the inside of the rim. 19 inch wheels would have slightly more clearance to the inside of the rim. MPP is running 19x10s +35, a mm less inside clearance than 19x9.5 +40.
I measured the inside clearance I have now with stock 18x8.5 +40 and its only about 5/8". But going from 8.5 to 9.5 at same offset would cause 1/2" less clearance on both sides of the rim. This will leave only 1/8" inner clearance which is absurdly small. Yes going from 18" to 19" diameter gives you a little more but how much more over that tiny 1/8"?
