On the top right of my screen between my driver setting name and the wifi strength indicator is a small black dot that shows a red center when touched. I have looked thru the owner's manual but still can not figure out what it is. Help???
Where did the car save the Sentry files when the black dot is pressed? The TeslaCam folder on the flash drive? If there's no flash drive plugged in, its not going start/show the red dot? Doesn't that connect the dots?
If you are recording via the dashcam feature while sentry is enabled though it will save the last 10 minutes of dashcam footage to the Saved folder when it enters alert mode.
You need to get a USB drive (formatted in FAT32) and plug it into one of the front USB ports under the phone storage lid if you want the car to record sentry mode incursions.
