rtanov
No need - I leave the car in D - it can still roll forward and at the end of the wash just push on the pedal to drive off.Automatic Car Wash: "Put car in neutral, foot off brake"![]()
How often do you use this? Have you ever truly used this?
Creep off, yah?No need - I leave the car in D - it can still roll forward and at the end of the wash just push on the pedal to drive off.
Because less is more. Until it isn't.Why not have a separate friggin stalk for AP? Why this silly design?
Neutral disables regen which can be useful when on icy roads.
Fair point, but you could also disable regen through the control screen. The number of times where you'd want to disable regen seems fairly low, so i think removing neutral makes some sense.
At least make it harder to get into neutral by changing from half a push up to a FULL push up
I don't see how putting the can in N would be safer than D. It's not like I am mechanically disengaging a motor or a transmission. The car can roll in both directions in D (provided that creep is off, of course), and as long as I make sure I don't accidentally step on the accelerator it's all good. Been doing this for more than 3 years with my i3's and now also with the TM3 for the half dozen washes I had to do so far.Is that safe for the cars and carwash attendants in front of you? Doesn't seem so.![]()
Iand as long as I make sure I don't accidentally step on the accelerator it's all good.
But you'd have to also consider that at the exit you'd have to switch back to D and drive off quickly - this does not always work on the first attempt and with another car quickly approaching behind you might be unnerving. I'd rather take the other risk.This is it. If you don't make a mistake it's fine. The other way makes it foolproof, therefore it's safer.
Ok just went for a drive to test out this issue......
If you hold the stock up in N (Neutral) while moving above 10mph or so the car goes into Neutral. This is what appears to have happened on the test drive above to an unfamiliar driver..
Here is what I discovered and should share..there are TWO ways to get the Model 3 back into Drive
1) As the pop-up message states, you have to press COMPLETELY press the brakes. That means stopping = Dangerous (I tried just holding it down lightly and that did not work as suggested above.)
2) The PREFERRED method that I just found out was...while coasting in NEUTRAL double tap DOWN on the stock to get the car back into drive WITHOUT having to stop..
Hope this helps someone...
This is new control behavior for Tesla. In the S and X you can engage drive while rolling just by pressing the stalk down to the drive position (second detent). I'd like some more consistency between their models.
It's the EXACT same in the Model 3, as has been said on this thread multiple times.
I put the S into neutral frequently when coasting down hill.How often do you use this? Have you ever truly used this?
I believe this is because he said he was only going 10 mph. There may be a threshold for requiring the brakes to be pressed. He should repeat the test at or over 25 mph to see if the situation changes.Really? The guy I quoted tested it and said that you either have to stop or double-tap the stalk down to engage drive while moving.
For clarification, that's double-tap to the second detent (like you would to engage Autopilot). The S & X can engage drive while moving with a single tap to the second detent.
Unfortunately, I don't have my Model 3 yet, so I can't film a video to show how it actually behaves. Perhaps someone else will oblige.
