Wow. You really aren't hearing what I am saying. You points are not from a consumer perspective. Mine are. From the consumer point of view it's blinding simple, Tesla should support ALL fast charging standards. Like I said, I really don't see how this isn't completely obvious.
Looking over our comments in this thread, seems we are arguing about completely different things.
1) Should Tesla release a CHAdeMO adapter?
My point: they will anyways for Japan so there is no need to discuss this. I'm not arguing it shouldn't exist (or that when it is released in Japan that it shouldn't be released in the US also).
2) When should Tesla release a CHAdeMO adapter?
My point: They should only do so at the same time as the SAE DC adapter if they want to remain a "neutral" party in the competition between the two standards. And this does include concern for the "consumer" as it saves them money in the long run.
3) Should Tesla (and SAE) create a different connector rather than using CHAdeMO?
My point: they have done so already and I have pointed out the reasons why. The reason that they both share is having a single port for AC/DC (there may also be royalty issues too).
My own stake in this: I'm a Gen III waiter and from a "consumer" perspective I would rather have most non-Tesla DC charging infrastructure be dual connector stations than CHAdeMO stations. The SAE DC adapter from everything I have seen so far will be far simpler/compact, easier to use, and less expensive than any CHAdeMO adapter that will be made.
At the same time, I certainly understand why people who have lots of CHAdeMO stations around them already (mainly those in WA, OR, TN) would want CHAdeMO adapter.
- - - Updated - - -
Isn't the Supercharger a beefed up SAE DC charger with PLC communication?
They might have some kind of proprietary layer (to prevent someone from coming up with a SAE DC to Supercharger adapter and using Superchargers for free), and it was never confirmed the supercharger as currently implemented uses the same protocol as SAE DC. It's quite possible that Tesla has their custom protocol on the superchargers, just that the Model S side can support both (maybe with a firmware update if not right now).
- - - Updated - - -
Problem is Chademo is 500V DC and Model S battery is 375V (nominal?) hence such an adapter would need to be a variable DC/DC converter.
This is not correct. CHAdeMO, like all DC charging protocols, allow the car to tell the charger how much the charging voltage is (which for the Model S is 400V) and the charger would output the correct DC voltage for the battery. CHAdeMO is definitely not outputting 500VDC and depending on the car to do more DC/DC conversion.
The bulky part of a CHAdeMO adapter is the need to simulate the CAN Bus and also the analog handshake (I suspect this part will take up more space/weight than the CAN Bus). The translation box precludes the adapter from being a simple "soda can" adapter (like the current J1772 and what I suspect the SAE DC adapter to be). There's also the fact the CHAdeMO connector is quite bulky/heavy. Think of it as a UMC except with much bulkier cabling and a female adapter end that can handle insertion of a CHAdeMO connector (rather than like the UMC with a male adapter end connecting to a power outlet).
