It is in ChargePoint's interest to have an option for Tesla cars as there is a lot of them on the road. It's up to Tesla to play ball and actually follow through with their 'everyone can use our patents' policy. If they are really open, they would provide the specs for the Supercharger system so others can make their charging stations compatible for Tesla cars. No one is going to risk coming out with a commercial product that is based on reverse-engineering and hacking an undocumented system that operates at 120 kW or more. Let's see how Tesla is cooperating. All other charging standards are open and documented.
I'm more than happy to pay for a fast charger that is making my trip more convenient. I have done so many times using CHADeMO stations where no Superchargers were available.
As for faster charging than current SuC, I believe the second generation Model S/X will have that first and exclusive, not the Model 3. As it is now the Model 3 will already have similar specs and range as the Model S at half the price. No one would buy a Model S any more if it didn't offer a few exclusive features.
To make the pictured ChargePoint station with the Tesla connector, all they had to do is cut the cable off a Mobile Connector.> Chargepoint wants to use the Tesla plug/handle. And has one rigged up.
So they got one out of a wrecked MS, and the results are: ??
The pictured cable is not as fat as a HPWC and their 30A station only needs a cable the size of the one on the UMC.Or just disconnect one from a HPWC. Which is probably more likely since it already has connectors on it...
Dosen't the Tesla Supercharger communicate in a similar war to the Chadamo standard? If I remember right the Chademo adapter converts the signal from analog to digital among other things. Assuming Tesla does not share the required information, couldent chagepoint reverse engineer a Chademo adapter and incorporate it into the fast charger.
I dont think its that simple, you cant just splice in a cable from a Tesla UMC. You have to be able to communicate with the car and have the car close the DC-DC contacts in order to fast charge. In addition, Chargepoint has liquid cooled charge cables (like Tesla) and they could probably adopt the same cable from the supercharger.
The biggest issue with Chargepoint (and all the others) is that all they have is a whole bunch of chargers - EVSE's for the pedants.
Chargepoint probably have more chargers in the US than Tesla, but they do not have a NETWORK.
The locations are not based the capability of any EV, they just stick the box anyplace a business asks without an overall goal.
So when these super fast charging options arrive, it will be a happy accident if it is useful to you.
Of course if that happy accident is close by then I'd choose it
Something that has slipped relatively unnoticed into the news is Tesla new superchargers at 350KW iirc.
This surely implies either more smaller cells in the pack - unlikely given the move to 2170 or that Tesla have upcoming battery tech that significantly reduces cell internal resistance. Lower resistance leading to lower heating during charging and potentially higher charge rates subject to a bunch of other chemical considerations.
This has even more interesting ramifications as lower cell IR would make higher discharge rates possible too - more power available - woohoo
The 2170 total production, assembly, deployment and QC should be on the order of 30% less than 18650 per kWh at maturity. (The 30% estimate may be too low).
The non-format-specific recent developments are also useful to think about:
1. The gradually increasing silicon content in anodes (began with 90 kWh power pack) has been extremely difficult to achieve due to the expansion habits of silicon, but Tesla/Panasonic made it work with some clever doping, et al, and by all reports has been able to expand the silicon content in the 2170s. BY how much, to what effect, they are not telling so far. We do know that that alone can make energy density more than double;
2. The advent of stable electrolytes, some actually 'solid' greatly improves charging stability so has many virtuous effects among them;
2.1 reduced risk of thermal inconsistency;
2.2 easier, cheaper manufacturing;
2.3 easier, cheaper and better cell management;
2.3 potentially reduced charging/discharging cell voltage imbalance, thus allowing tighter operating margins.
3. Then we can add myriad of small chemical, process and operating improvements that Tesla/Panasonic have already achieved.
That all makes me think we might be underestimating the benefits of all those things grouped under the single topic of 2170. We also probably are underestimating the potential impact of the megafactory.
Thus, I fully expect to see Tesla move to 2170 exclusively quite soon. After all, going to Powerpack/Powerwall with 2170 first only makes sense if they are much cheaper than 18650. The equipment used for 18650 can be used by Panasonic for other purposes anyway, since that format continues to be extremely useful for very space-sensitive applications, but, as JB says, certainly not optimal for a BEV.
<snip>
So, despite my long-winded ways, I think Tesla/Panasonic have solved several serious problems more or less simultaneously. I do not think most outsiders have much appreciation for what they have done. Thus I think they're about to go all-out for 2170 for the near future.
Finally, Tesla advances in manufacturing technology are underweighted, I think. Probably their dramatic overreach on the Model X ("hubris", Elon said) has caused many people to be sceptical, justifiably so. Now we have a different story, the tesla industrial quality control in batteries started the learning curve. The Model S design taught large scale robotic deployment skills. Model X taught the limits. Model 3 will be the result of a decade of high intensity learning and will not repeat past mistakes.
IMHO much of the Tesla success story is "all about the cells". If I am correct we'll see the decade of experimentation producing near-magic late next year.
If I am incorrect I'll probably go in "thermal runaway" myself.
I was thinking this same thing. What EV could handle a 400kwh charge other than Tesla? OK I guess the charging stations can be adjusted for the Bolt, i3 etc...........But until legacy automakers decide to build them, they will not comeanything with faster charging capability than current charging of Tesla battery packs (with superchargers) is somewhat pointless
I don't know the exact timing, but I absolutely expect to see a P120T show up later this year ...
Source? If true it seems pretty stupid on Tesla's part.Tesla has asked ChargePoint to remove the Tesla plug from their display in Las Vegas, and that was done.
Of course you are correct today. There is some serious effort underway to achieve charge rates and charger support much faster than those of today. We all understand that neither the batteries nor the charging infrastructure are capable today. I have been around long enough to remember when there was no:No car can handle 400kW... nor is one planned, that I'm aware of. Trucks, buses, ferry boats, sure, over 1MW. But not cars.
The fastest that ANY current production car will charge on this ChargePoint unit is 120kW... with a Tesla. The same speed as a Tesla at a Supercharger.
The fastest charging proposed production car would be the Porsche MissionE, which would be nearly the same 350-400 amps that a Tesla can accept today (Tesla is 330-365 amps max), but at double the voltage. That means realistically it might actually charge at 250kW, and maybe as high as 300kW (400a * 750v), however I find both those figures very unlikely. I guess we will see in a year or three.
