I believe the Bolt EV will come to a full one-pedal stop without using the paddle in Low but using the paddle will strengthen it even more.I stand corrected then. I was under the impression the paddle was just a simple on/off switch that did not need to be held continuously. By your description, it is an on/off switch that must be held continuously and the Bolt made it various.
If so, I understand some of the criticism raised in the comments in that article. This is isn't really a "one pedal" design, but rather a "one pedal and one paddle" design.
You wouldn't want maximum regen just by releasing the go pedal because that could be too jarring and dangerous if released by mistakenly -- the Model S regen brakes a maximum of 60 kW (at highway speeds) even though the motors and battery pack could clearly do more.
The Bolt EV allows you to use the paddle to intentionally ask for even stronger regen than would be safe or comfortable just on the "go pedal".
