What is the likelihood that GM can do an AWD Bolt and ship it before the Model 3 AWD is released?Not yet. While not always the case, usually GM products get a Year Two bump. Things the engineers did not finish in time (shoot the engineer and ship it) often get incorporated into the second year.
I have a very strong hunch there will be items added to the Bolt. The fact that the Social Networking interface did not appear even though Mary mentioned it, and the lack of ACC even with radar and 360 cameras, and full autonomy Bolts on the road since June '16 sort of point that way.
But who knows?
Not necessarily, my car with AC induction can come to a full stop with regen alone if I'm not going too fast, PM motors should have even stronger regen potential all the way to zero mph.
Most EVs including Tesla models noticeably lose their apparent regeneration torque at some speed below 5 mph.I assume this means that once the RPM drops below the point that actual regenerative torque is available from the motor, that the system applies pack power counter to the motor direction to bring it to a stop?
Just to be clear, the production 2017 Bolt does not have radar. Occasionally there has been confusion about that in articles and car reviews.and the lack of ACC even with radar and 360 cameras, and full autonomy Bolts on the road since June '16 sort of point that way.
Does the rear end layout suggest a drive unit could be added there without significant rework?
"Bolt EV has the technology available to help make your driving safer, including a number of ingenious radar- and camera-based systems for protection on all sides."
The problem is that to regen you have to make 300-400v to regen, which gets more and more difficult as the electric motor slows down. It starts 'pulse' and you can sometimes feel it in electric motors at very low speeds.
I can feel a very faint motor cogging in the RAV4 EV (Tesla drive unit) when inching up an incline.I believe that cogging effect is more a factor with PM motors than induction. I certainly don't have that effect in my car.
Somebody better notify Mary in a hurry! 2017 Bolt EV: All-Electric Vehicle | Chevrolet
Also read this: GM Could Soon Roll Out World’s Largest Autonomous Fleet - GM-VOLT : Chevy Volt Electric Car Site Search on 'radar'.
Do you have a way to monitor 58 GHz? radiation? (I'll try to find the number again, going off memory)
No one "vowed" anything. The quote is:
This was a year ago. Not only is this not a promise, but it's a rough guess made long before now.
Although I have no personal knowledge about how BMW implemented full stopping ability in the i3, people have said that it can use friction brakes. Assuming this is true, I'm not clear on whether it does this all the time or only when regen is weak or unavailable due to a full battery or cold battery temperatures.
I spoke with a senior GM Bolt engineer at a vehicle media drive event several months ago and was left with the impression that the car does, in fact, use a little battery power to the motor to bring the car to a complete stop and hold it there even on an incline.
Are you sure she isn't talking about the blind spot/cross traffic system? That's generally radar based...
Accurate camera based ranging (to the accuracy required for following distance) actually isn't too difficult. Rather than relying on size (which can only give a rough guess given 30% accuracy due to variance on vehicle size) it relies on the distance the bottom edge of the object is at. This gives error of 10% at 90 meters, 5% at 45 meters (for a VGA camera).The Bolt has a following distance indicator that appears to range exactly like our radar equipped Volts and Cadillac. Ranging is difficult for cameras since they don't know the object size, and it's WAY out of range for ultrasonic.
Perhaps the Bolt does not have forward looking radar and is using video image range-finding, if so, it's impressive.
It depends on the torsional rigidity of the chassis. There is room. If the chassis is not stiff enough, then problems will occur since the battery array is a stressed member.
Perhaps the Bolt does not have forward looking radar and is using video image range-finding, if so, it's impressive. It appeared to work as well as radar. If that is the case, it doesn't need radar for ACC.
