Keep in mind that Tesla is a full member of CHARiN, the body that set the CCS standards. There is plenty of upward capability within teh standard but NA does nto any of it deployed because there aren't vehicles around that can use it, so far.This is a European concept with ratings based on 1000 volt battery EVs. Doubtful that this station today at Baker, CA, USA is offering anything other than what you would find in Sacramento or San Francisco at a 'fast charging DC EVSE'. So nothing new here wrt Teslas which are 400 volt EVs.
The only car I know of in the USA that has untapped potential for fast charging is the Kia Soul EV. It can allegedly use a 100kW charging station. I think that means 200 amps DC. So, this proposed station, which I think will be 1,000 Volts and up to 350 Amps on both CCS and CHAdeMO will definitely charge that car faster than other stations currently installed. However, it might only increase from 50kW to 80kW. The big question in my mind is what the ratings will be for the vehicle connectors on this station when it is first running in June 2017. I don't think the handles available at that time will be rated for 350 Amps.Keep in mind that Tesla is a full member of CHARiN, the body that set the CCS standards. There is plenty of upward capability within teh standard but NA does nto any of it deployed because there aren't vehicles around that can use it, so far.
Right now for NA most of what we have is speculation. Almost all NA CCS are colocated with CHAdeMO, and usually about 50 amps or so with 300 or so volts, somtimes a bit higher. I think there will be little faster charging for either CCS or CHAdeMO until there are a few long range EV's around to use them. Even in Europe, other than Tesla Superchargers there is not much really fast DC. The Bolt could help change taht, but GM is pretty much hands off, so I think faster CCS probably is waiting for the Germans to arrive in force 2019/2020. Sometime around then we'll probably have some wildly complex CCS adapter for Tesla, although that one has some serious problems since CCS requires a/c for the network.The only car I know of in the USA that has untapped potential for fast charging is the Kia Soul EV. It can allegedly use a 100kW charging station. I think that means 200 amps DC. So, this proposed station, which I think will be 1,000 Volts and up to 350 Amps on both CCS and CHAdeMO will definitely charge that car faster than other stations currently installed. However, it might only increase from 50kW to 80kW. The big question in my mind is what the ratings will be for the vehicle connectors on this station when it is first running in June 2017. I don't think the handles available at that time will be rated for 350 Amps.
Speculation is that the Bolt EV will also be able to take 200 amps DC on its CCS port.
Some corrections to your post. In North America, the vast majority of non-Tesla DC Fast chargers fall into two groups.Right now for NA most of what we have is speculation. Almost all NA CCS are colocated with CHAdeMO, and usually about 50 amps or so with 300 or so volts, somtimes a bit higher. I think there will be little faster charging for either CCS or CHAdeMO until there are a few long range EV's around to use them. Even in Europe, other than Tesla Superchargers there is not much really fast DC. The Bolt could help change taht, but GM is pretty much hands off, so I think faster CCS probably is waiting for the Germans to arrive in force 2019/2020. Sometime around then we'll probably have some wildly complex CCS adapter for Tesla, although that one has some serious problems since CCS requires a/c for the network.
communications.
BTW, Tesla in Europe has Mennekes 2 connectors but use proprietary pins for Supercharging.
Group 1. 25kW single standard chargers. Examples - BMW i Fast Charger (SAE/CCS only), same as ChargePoint Express 100. Same unit, made in France by ICS and ~60 amps DC max. Similar units by Fuji for CHAdeMO only were deployed in small numbers. A 2014 CEC grant recently resulted in CHAdeMO-only units (unknown manufacturer) being installed on I-5 and CA-99 with similar specs.
Group 2. 50kW single or dual standard chargers. Major manufacturers are ABB, BTC, Nissan (DBT?), Signet. These chargers can all deliver between 100 amps and 125 amps at up to 500 VDC. Nissan is CHAdeMO only but the others are all dual-standard CHAdeMO and SAE/CCS. There were some (<5 units) ABB SAE-only chargers installed by NRG at the very beginning of the SAE deployment, but I think they've all been replaced with dual-standard chargers. Likewise, in places like Georgia some BTC chargers were installed without the SAE cable, but I believe these have been added since the initial deployments.
Personally, I don't think a Tesla CCS adapter will be any more difficult overall than the CHAdeMO adapter. They both have to be smart adapters, not just dumb pass-through units like the TSL-02 J1772 adapter.
Plus European ones, plus a pretty detailed evolution plan for very high power.AFAIK,
There are 3 flavors of CCS:
EVgo 62.5kW
Chargepoint 50kW
Chargepoint 24kW
Those are just the external branding. EVgo and Chargepoint are not charging equipment manufacturers.AFAIK,
EVgo 62.5kW
Chargepoint 50kW
Chargepoint 24kW
I'm pretty sure there is no EVgo DC station in Baker yet -- that's just a computer rendering of what it will look like.Doubtful that this station today at Baker, CA, USA is offering anything other than what you would find in Sacramento or San Francisco at a 'fast charging DC EVSE'. So nothing new here wrt Teslas which are 400 volt EVs.
The new CCS spec is for 350A and chargers implementing the full 350A of power will be using water-cooled cables and plugs. Tesla has recently experimented with water-cooled cables that can handle at least 350A are they were actually thinner and easier to handle than the regular non-cooled Supercharger cables.Yeah... I noted that rendering didn't have charge cables the size of tree trunks, so there's no way they are handling ~860A.
Why is that? As far as I can tell, suppliers like Phoenix Contact already have prototype water-cooled 350A CCS plugs and are very likely to be ready for volume production next year.The big question in my mind is what the ratings will be for the vehicle connectors on this station when it is first running in June 2017. I don't think the handles available at that time will be rated for 350 Amps.
I've never seen a CHAdeMO station with less than 62A and most seem to be 100A or 125A. All of them are capable of over 400V -- usually 450V or 500V.Right now for NA most of what we have is speculation. Almost all NA CCS are colocated with CHAdeMO, and usually about 50 amps or so with 300 or so volts, somtimes a bit higher. I think there will be little faster charging for either CCS or CHAdeMO until there are a few long range EV's around to use them.
I believe the signaling for CCS is carried on pins that are already the same between J1772 and Tesla's NA plug. The circuits and chips that support CCS signaling over these pins is already widely available and straightforward to implement. The only real issue is the higher-level messaging protocol translation between the messages exchanged during Supercharging and the messages exchanged during CCS charging.Sometime around then we'll probably have some wildly complex CCS adapter for Tesla, although that one has some serious problems since CCS requires a/c for the network.
I believe EVgo has some 100A chargers as well as 125A. Only 125A stations can, at least theoretically, do 62.5 kW at their rated 500V maximum. Stations that support 125A are sloppily called 50 kW because most actual vehicles charge at around 400V.AFAIK,
EVgo 62.5kW
Chargepoint 50kW
Chargepoint 24kW
CCS is not doing 860A plugs so forget that. They are doing 350A although the spec might have some wiggle room to allow a little higher for short durations.Hence my point that the voltage on that 350KW station would have to be in the 1000V range... 350A plugs are doable. But 860A plugs, even if fed by liquid cooled cables would be a challenge... contact size in the plug housing, conductors in the car, etc...
