Commercial Crew Transportation Capability (CCtCap) SpaceX and Boeing developments
Discussion in 'SpaceX' started by Grendal, May 12, 2016.
Tags:
  1. mongo
    mongo Well-Known Member
    Michigan
    CRS-7 on a v1.1 F9 wasn't a reflight though, so it shows the value of flight proven hardware.
  2. adiggs
    adiggs Active Member
    Portland, OR
    I sort of expect a 2nd and maybe 3rd flight constraint as well. SpaceX needs to demonstrate a bunch more 4th, 5th, etc.. flights before those will be usable for crew (IMHO).
  3. SO16
    SO16 Active Member
    MI
    Reusing the rockets for human space flight won’t be an issue. But reusing a capsule for human space flight after landing in salt water will take more refurbishment costs.
  4. Grendal
    Grendal SpaceX Moderator
    Santa Fe, New Mexico
    #864 Grendal, Jun 9, 2020
    I'd expect what we've seen demonstrated with the CRS reuse that NASA allowed. They buy a launch on one booster then reuse that same booster for another launch. It is "their" flight proven booster.
    I don't think the reuse scenario includes capsules at this time. You are correct. That is an entirely different type of reuse with different parameters for reuse needed. NASA might wait for SpaceX to do a capsule reuse with a commercial tourism customer before they allow one of their astronauts to launch on a reused capsule. NASA would want to do a thorough examination of the reuse process before okaying such a thing. NASA does know the capsules very well since they oversaw every part of the build process - seeing the refurbishment process should tell them what they need to know.
  5. mongo
    Michigan
    They're working on that. From Elon Q&A
    Informal Q&A with Elon after formal IFA press conference : SpaceXLounge
    • Informative x 2
  6. ecarfan
    ecarfan Well-Known Member
    San Mateo, CA
    “Dragon has been designed to be reused. It has bilge pumps and other features to waterproof the vessel”
    Bilge pumps on a spacecraft! Hilarious. But in this case, logical.
    I wonder how many person/hours are required to make a flight proven Crew Dragon ready to re-use. My guess: a few thousand.
  7. Cosmacelf
    Cosmacelf Well-Known Member
    San Diego
    If a spaceship is vacuum proof, why wouldn’t it be waterproof and not need bilge pumps? In case of something cracking during re-entry or the landing?
  8. mongo
    Michigan
    Different requirements, vacuum is not conductive nor a solvent. Don't need to keep vacuum out of connectors or piping. Heatshield is continuous, but all non crew volumes need to vent on launch and re-entry.
  9. Nikxice
    Nikxice Active Member
    Hudson, NH
    Although brief, Boeing just released this virtual reality video of Starliner's cockpit display. It might provide us with the most detail we've seen up to now. It does have EFIS (electronic flight instrument system) and lots of other bell & whistles. Plenty of toggle switches, rotating dials, push buttons, keypads, along with a couple of joysticks. Everyone is also probably familiar with the highlighted striped barber pole T-handle in the middle.
    Is it all good or too cluttered for a modern spaceship today? I guess it depends upon who you ask!
  10. Cosmacelf
    San Diego
    I’m not opposed to hard buttons. It’s a balance. You want touchscreen for certain things for reconfigurability and buttons for others.
  11. bxr140
    bxr140 Active Member
    Bay Area
    I think it also depends on how much control you believe the crew needs.
    Intuitively, the ideal balance between touchscreen and hard controls is what you can find in a modern aircraft cockpit--say, something like a 787 or 350. Those are explicitly designed to provide maximum ability to operate the vehicle, at a safety margin certainly more stringent than space. Maybe the heavy aircraft example is a little biased toward hard controls than they need just because humans don't like change, but you get the point.
    The main point, because of the way things happen in space and the speed at which they happen (either REALLY fast, so control has to be automated, or pretty slow, so remote commanding is no problem) there's much less real time demand on the operators of the vehicle, so the controls can bias toward providing maximum information and flexibility for the operators over maximum control.
    Rare for me to side with Big B, but I think the Boeing solution actually strikes a pretty nice balance between the ultra clean Dragon solution and the classic SLS aircraft-like cockpit. Its closer to a modern fighter cockpit.
  12. Grendal
    You can definitely tell that the cockpit isn't designed for commercial use.
  13. bmah
    bmah Moderator, Model S/X, California Forums
    Lafayette, CA, USA
    Bruce.
  14. SmartElectric
    SmartElectric Active Member
    Toronto,Canada
    I see you and raise:
  15. Brass Guy
    Brass Guy Active Member
    Holbrook, MA
    I see I'm not the only one that noticed the green outline of a galaxy class starship on the display.
  16. e-FTW
    e-FTW New electron smell
    San Francisco, CA
    Cannot un-see!
  17. e-FTW
    San Francisco, CA
    If something goes really south and you need to manually regain control of a spinning/yawing/tumbling ship, would a stick be better than the SpaceX combo of “finger rail” and push buttons (I assume that row of buttons has attitude controls)?
    This is probably a moot point as automation is supposed to handle that for you, like stability control does on a car...
  18. Nikxice
    Hudson, NH
    Twitter post by Michael Sheetz
    And to answer that 16 year old question....Rock they can!
    • Like x 6
  19. Cosmacelf
    San Diego
    Wow, the Falcon 1 was a really tiny rocket!
  20. ecarfan
    San Mateo, CA
    Incredible. What SpaceX accomplished in just 16 years is mind boggling, though I think only a tiny fraction of the American public understands just what an accomplishment it is.
    I don’t always agree with Elon, and his timelines can border on being laughable. But I never underestimate him.
    • Like x 4
