I turned them on a metal lathe. The big Tesla power inlet pins are 9 mm. Exactly the same diameter as pins in the big clunky CHAdeMO plug. The Tesla's ground pin is 3.66 mm. Exactly the same diameter as the power pin on a J1772 power inlet.
While I can appreciate your ingenuity, I am disturbed by your egoism.
While you are getting a free charge you may very well be the
HPWC Typhoid Mary with the adapter contacts turned on your lathe.
I anticipate you are not a electrical engineer/electrical contact designer and have yet to have the knowledge to understand the metallurgy of electrical contacts and the effects of these material under a high current load.
These contacts need to be made/designed from the correct materials with the contacts positioned within tolerance and correct float within the housing to prevent spreading the contacts and life tested to insure they work as intended.
That is, each and every HPWC you use your adapter (or others that have Rube Goldberg an adapter) may very well be damaging the HPWC output connector by the transfer of metal from your Rube Goldberg connector to the HPWC output connector.
Then when your Tesla buddy uses that HPWC after your adapter has dirtied up the HPWC output connector the connector drawing 80 amps could fail and/or damage and/or dirty up the cars charge-port connector.
This may not show up as frequently using the HPWC but when we use a Supercharger the dirty charge-port connector may fail.
Should the charge-port on a Tesla fail at a supercharger the car is of little use for the intended trip until the charge-port is replaced
So now along with range/charge anxiety we now have to contend with non-Tesla adapter damaged output connector anxiety.
While you and others think it is cool to build an adapter to get over on Tesla, I do not think it is cool at all.
I could care less about the cost of the electricity it is the abuse of the EVSE hardware that I need to use that disturbs me.
