The other way around, but yeah that's the idea.They are not as you report them. They are kw and kwh.
One is the amount of fuel put in - 8kw
And the other is the rate of fuel flow - 10kwh
is 8kw about right or should I be seeing more, I have a Tesla gen 3 which I thought was rated at 11kw ?8kW power - how fast the water is flowing
10kWh energy - how much water is in the sink
7kw (32amp) is about right for single phase, the gen 3 needs 3 phase to output 11kwis 8kw about right or should I be seeing more, I have a Tesla gen 3 which I thought was rated at 11kw ?
Read the manual!thanks everyone - first day with new car so lots to learn...
Also should we be helping the Dark Lord of the Sith?Read the manual!
Seriously, the majority of questions new users have can be answered by looking at the manual or searching on here. We'll await your "I'm not getting the range I expected" thread. Seems every new user needs their own thread for that one
Perhaps some uncharitable comments about reading the manual, the wall connector manual isn't very clear. Some general reading/watch around EV topics would have show the answer.is 8kw about right or should I be seeing more, I have a Tesla gen 3 which I thought was rated at 11kw ?
Totally agree, we tend to use far more of the features of a Tesla than other cars and the manual is very clearly written. It helps that all the cars are more or less the same, my previous BMW manual was impossible as every paragraph depended on which options you had selected, engine size, trim level etc.My comment was not specifically about charging but guidance for a new user. A lot of the questions we get on here can easily be found in the manual. If the OP has a lot to learn then its a great place to start.
That's a good point. I'd forgotten about that minefield with BMW - and the supplementary books dependent on your choice of infotainment.Totally agree, we tend to use far more of the features of a Tesla than other cars and the manual is very clearly written. It helps that all the cars are more or less the same, my previous BMW manual was impossible as every paragraph depended on which options you had selected, engine size, trim level etc.
Thats actually because there seems to be a fault at the moment. If you don't charge an LFP to 100% regularily then there is a risk the new Lithium-Ion Low Voltage battery will go flat quickly, something to do with main battery caliubration, especailly when the main battery drops below 20%. They'll probably make it more tolerant to the problem with a software update at some point but the big push at the moment is to stop people accidently bricking their new cars.Due to collect my M3 RWD tomorrow which of course will have LFP battery. Just got an SMS from Tesla telling me to charge regularly to 100% and to charge to 100% as soon as possible after taking delivery - to maximise performance of the battery. Tesla clearly making sure that new owners understand the different charging strategies for different versions of M3.
My understanding is this is applicable only to the Model 3 with the new low voltage batteries and the li-ion battery on vehicles equipped with LFP batteries can die in less than 20 minutes after the vehicle’s main battery reaches a state of charge of less than 10%. When this happens, the car cannot be started or even charged.Thats actually because there seems to be a fault at the moment. If you don't charge an LFP to 100% regularily then there is a risk the new Lithium-Ion Low Voltage battery will go flat quickly, something to do with main battery caliubration, especailly when the main battery drops below 20%. They'll probably make it more tolerant to the problem with a software update at some point but the big push at the moment is to stop people accidently bricking their new cars.
Don't worry about it though, just stick it on a 100% charge as soon as you can and until then try to avoid dropping below 20%.
