AlanSubie4Life
Efficiency Obsessed Member
With "hundreds or maybe even thousands" of young people dying, the math states they must be essentially immunocompromised outliers.
No, it doesn't follow that the people who die have to be immunocompromised individuals. I suspect the distribution is similar to what happens for all respiratory illnesses - immunocompromised individuals are at higher risk, but if you get unlucky, you die.
Far too many millions of young people have been infected for the math to state otherwise. We'd have 1M+ dead young people if that were the case.
That's not true. COVID-19 is not that deadly to the young, as I said. That's how the numbers work out. This isn't complicated. It can kill you if you're young, but it's not that common. But it's common enough to raise excess mortality (because young people don't typically die from respiratory diseases)
so far, many more Americans under 35 died in the Swine Flu pandemic of 2009.
Do we really have to revisit these numbers? They're elsewhere in this thread, so please refer to those well-researched numbers. Again, I'd like you to be correct, but this is just false.
The US CDC said:From April 12, 2009 to April 10, 2010, CDC estimated there were 60.8 million cases (range: 43.3-89.3 million), 274,304 hospitalizations (range: 195,086-402,719), and 12,469 deaths (range: 8868-18,306) in the United States due to the (H1N1)pdm09 virus.
The US CDC said:This epidemiological data supports laboratory serology studies that indicate that older people may have pre-existing immunity to the novel H1N1 flu virus. This age distribution is very different from what is normally seen for seasonal flu, where older people are more heavily impacted.
CDC Novel H1N1 Flu | 2009 H1N1 Early Outbreak and Disease Characteristics
There's no question that swine flu tended to be more deadly to young people RELATIVE to COVID-19 (see above: likely due to attack rate) but the claim that more people under 35 died in the swine flu pandemic does not stand up to a look at the evidence. And as mentioned above, part of the reason for the distribution is because young people dominated the swine flu infections! So that was likely due to 50 million infections in the young (80% of the infections were below age 49, alone)! That's a lot, and much higher than the attack rate for COVID-19 in the young.
For the charts below, these are CONFIRMED deaths, so they don't add to 12000 (best estimate of swine flu death total in US), of course, but it allows extrapolation. Implies: 2000 deaths below age 24, with about 40 million infections, for swine flu.
I can't directly compare to below 35 with this data, but I would estimate it was about 4000 estimated swine flu deaths in that age bracket. (Just from the charts below, estimating.). Compare to 2500 confirmed deaths with COVID-19, with substantially fewer infections. (Probably 45-50 million for swine flu vs. 35 million for COVID-19.)
Conclusion: that's likely less deadly than COVID-19 - we already have 500-600 confirmed deaths below age 24,with 2500 confirmed deaths below age 35, and we know there have not been 40 million infections in those age groups (best estimates are 70 million infections in all age groups in the US, total, for COVID-19 - and in this case many are in older people). And remember, we just have the official numbers from the CDC of deaths - these do not include uncounted COVID-19 deaths, which you can see likely exist, and are substantial, from the excess mortality data (see link below). There are a few unlucky young individuals who are dropping dead of COVID-19 (likely due to clotting/stroke/cardiovascular side effects). Some of these are not counted. You have to compare apples to apples: we have ESTIMATES of swine flu deaths, and you're comparing to CONFIRMED COVID-19 deaths. Look at excess mortality by age group for 2020 to fill in the picture....
https://jamanetwork.com/journals/jama/fullarticle/2774445
"Only 38% of all-cause excess deaths in adults aged 25 to 44 years recorded during the pandemic were attributed directly to COVID-19. Although the remaining excess deaths are unexplained, inadequate testing in this otherwise healthy demographic likely contributed. These results suggest that COVID-19–related mortality may have been underdetected in this population."
So, I would say there have likely been at least 5000 deaths from COVID-19 for age 35 and below. Probably out of about 35 million infections.
So you can see with the above data, it supports my hypothesis:
COVID-19 will prove to be more deadly (per infection, AND on an absolute basis) than 2009 swine flu to the young (though it's not a huge difference - probably by at most a factor of 2 per infection- substantially more dangerous, as I originally said).
This is a deadly disease to young people! That's the message! It's worse than swine flu (which was bad!).
For anyone following my personal saga...
I wish you both the best, and that your wife turns the corner shortly with no long-term effects. Interesting that they are still prescribing hydroxychloroquine; I thought that ship had long since sailed. Anyway. From what I have read, the monoclonal antibody treatment can only be given to non-hospitalized patients, so it seems worth it to ask for it early before things get worse (seems like it would be past that point for your wife, tbh, but I am not a doctor). My layperson's understanding is that it has to be given before any significant damage is done. Of course it's probably not available unless you're a VIP; this is America after all. Anyway, hopefully all of this is unnecessary for you and your wife, in any case.
