SageBrush
REJECT Fascism
That is what I looked at and readThe Ventilator SOS site under the "Our Solution" does have a few diagrams of how it would be set up.
nearly all tests should be limited to those showing symptoms.
UVC light at 254 nM is the ideal output for disinfecting.I think even UV will break the masks down, but slower process in doing so, and enable reuse of a few times.
I've been interested in the results of disinfecting as for a home user and without access to any additional masks that I have and given to my mom to use, it does concern me about reuse. I don't think I've seen any articles with test results for masks put out in the sunlight.
I know there are different wavelengths for UV light bulb/tubes sold and wondering if someone has a UV blacklight (for GID purposes like at halloween time) there would be any benefit to using those type of lamps. Anyone?
I saw this TV Fox61 news story online about a company, Avon, that makes a product called ReadyDock that utilizes UV light to sanitize. Avon company ReadyDock using UV light to sanitize surgical masks amid COVID-19 pandemic (incl. Interview video with CEO/founder and demonstrates how it works).
In a state of 40 million people there are going to be a lot people with these symptoms.I find it interesting that only about 1 out of 10 tests is showing a positive, when in theory, nearly all tests should be limited to those showing symptoms.
Yes, but perhaps far less than you imagine.The number of people who die is dependent on the quality of medical care they receive. I think that should be uncontroversial.
Not sure what your point is. That the number of deaths has variable dependencies as well?
I guess I didn't understand what you meant by this?That's a great list, and for a moment I thought you are going to lift this discussion to a scientific level. Like when kids are having a pillow fight in the living room and then the parents come home.
@SageBrushThis graph repeats the one from this AM, but with additional graphic cues for people with reduced color sensitivity.
Please give feedback and suggestions
Robin
Yep.I think I may have realized you have both daily? and a moving avg on top. It seems to jump out.
I was just thinking the same. Thanks for the motivationEveryone can see black so maybe use that instead of 2 versions of yellow. Also the shapes used on the two versions of yellow are closer in form than the other shapes, so if you have to use similar colors give them more distinct shapes.
I was including all hospitalizations in my definition of medical care.Yes, but perhaps far less than you imagine.
On a population level:
Those who are not infected do not die
Those who are infected but do not reach the level of seeking out testing do not die. Unknown fraction
Those who are infected and tested but do not reach the level of needing hospitalization do not die. About 7/8 in Florida
Those who are infected and hospitalized but do not reach the level of needing ICU need O2 but otherwise do not die. About 3/4
In the ICU, expertise matters a lot but 80% die regardless
Not clear whether the 12k positives correspond to 113k tests or not …California Dept. of Public Health reports that they are down to only 13,000 pending tests (from approximately 60,000 earlier this week).
Great to see the backlog getting cleared.
State Officials Announce Latest COVID-19 Facts
