The Austin location apparently has a terrible service manager named Anthony Martinez who is widely hated in reviews and whose crew leaves cars worse when they leave than when left there. It seems some of the other people at the location are decent, however. My experience with BMW service has been largely fantastic and my car problem free.
They kept telling me they are not getting error codes thus they cannot help me
The Austin service center has been EXCELLENT. And so was Tony. Are these reports on the BMW forum?
Electric driving certainly needs a bit of a different mindset. Glad you are enjoying the BMW.
Your screenshots are normal supercharger speed. It will get to 80% in 40min.
It appears from your post that you have not read that OP has been unable to stay above 74 kw charge rate for more than a few seconds so this is not normal supercharging behavior.From the OP, it seems that he is complaining about what appears to be normal Supercharging behavior.
That is nowhere near normal supercharging speed.
If pack temperature is 75F or above and you're not paired with another vehicle that's charging, you should be getting a 115 kW charge rate, and it should be sustained until 40-50% state-of-charge in a Model 3.
I have two Model 3s and a previous Model S 85D. Normal supercharging power draw can always be approximated by calculating:
130 - [State of Charge in %] = kW rate
Model 3's and 100kW packs in Model S/X will do even better than this.
Both of my Model 3's do better than this calculation, and my Model S held pretty well to this calculation.
Getting a 58 kW charge rate with a pack at 17% state of charge would only be considered normal at low or near-freezing temperatures.
If you are referring to the 4 charge graphs posted above then yes this is normal supercharging, however, I am not the OP and my car charges normally, I was posting these graphs to show the OP what he SHOULD be getting but is not.It will never do that. Not even close. It has never stayed above 100 Kw for long. I have not timed it.
It should last longer than 10 seconds though if you started out above 100 Kw.
It goes down quick because your adding at rate of over 500 mph.
You will never see over 100 Kw if SOC is over 50%
Most everything you've said follows the chart that was posted. You'll not on the Red line, but not that far off.
I don't have a lot of warm weather experience but if it sees the pack is to warm it will not charge fast either.
Just because it's 75F doesn't mean what your battery is at. You could have been pushing hard and battery is warm.
Or it was a cold night and warmed up fast, but the battery is not warm yet.
You'd really have to state a lot more parameters to judge if your battery has and issue.
But with what you have shown it's all feasible for "normal" behavior.
We'd all love to see 115 Kw for 40-50%. But that would be double what Tesla claims.
115 Kw is over 500 mph. 50% of a 310 mile range battery is 155 miles.
That would be 155 miles in 18 minutes. Sorry pal, that's not gonna happen.
View attachment 377647 View attachment 377648 View attachment 377649 View attachment 377650
Some of my Supercharger curves
We drove a Performance Model 3 from Colorado to Nevada and easily got 116 kW for sustained periods of 15 minutes or more. I've also easily charged at 115 kW for sustained periods driving in Colorado and Kansas in an S 100D.I took a trip after I got my car and here are some charge numbers..with warm battery from driving...(sorry for the horrible format)
(Outside Temp) (SOC Start) (kw start) (SOC End) (kw End) Time
34 20 113 30 112 4
35 30 116 40 113 4
35 40 116 50 107 10
30 40 86 50 72 4
36 50 107 70 66 11
37 70 66 80 41 18
These weren't all necessarily from the same charging stop. This does show however that staying above 100kw is possible at least for me for up to 18 minutes at least from 20-50% SOC.
