So will the OEM tailgate power button fit plug and play with the co zero kit? Or is there other modifications and tapping into wires?
Can you please confirm if the official tesla oem tailgate button works plug and play with the cozero v2 kit with soft close? i dont want to tap into any wiresTesla button and the PLG from COzero V2.0
So wires do need to be spliced or moved around?
For anyone else that might be a little shy of just wiring this up. Here is how I wired the factory button on the v2 kit.
View attachment 256502 View attachment 256503
From left to right on the button. From the connector with the button in the box go Green/Black/Purple.
I installed my 1. gen kit from Che1/Autoease 18 months ago and it has performed fairly well except for the occasional uncommanded closing of the trunk.
Recently though, two annoying problems have surfaced. The first is the uncommanded closing, only now it happens 8 out of 10 times I open the trunk. It seems to be temperature dependent, on really hot days it just will not stay open at all!
The second issue is that both struts are ratteling, the righthand side much more than the left.
There is significant play between the inner and outer tube resulting in a very audible ratteling noise that is present when going over even small bumps, speeedbumps etc.
I wrapped the outer tubes in waterpipe insulation foam to give the strut a bit tension when stowed, that killed the ratteling noise and fixed the problem.....it does look pretty ghetto though
So then, would this qualify as a warranty case or should I just suck it up and order a new kit from COzero?
Going back to manual opening is not an option
I bought the gen1 kit from autoease in March 2017 and the only issue is how hard it slams the trunk. I emailed autoease and they sold me an upgrade kit which comes with a new control box and a power latch. I installed them last night the soft closing works very well.View attachment 354895
How much was it for the upgrade kit?I bought the gen1 kit from autoease in March 2017 and the only issue is how hard it slams the trunk. I emailed autoease and they sold me an upgrade kit which comes with a new control box and a power latch. I installed them last night the soft closing works very well.View attachment 354895
Can you share links to the product?I bought the gen1 kit from autoease in March 2017 and the only issue is how hard it slams the trunk. I emailed autoease and they sold me an upgrade kit which comes with a new control box and a power latch. I installed them last night the soft closing works very well.View attachment 354895
