Does 2019.5.15 update have 5% power boost?
I received 2019.5.15 last night and I always charge to 80% which would show 248 miles (and within like 10 minutes, drop to 247 or 246). This morning my 80% charge shows 252 miles. So there has been a bump there. I can't tell about performance because it's raining, so traction control is kicking in real early.
90% Long Range
Reactions: davedavedave
Best place to look is figure out where your Reference line is drawn on the Energy Chart.
It's drawn at around
241 wh/mi on RWD works out to around 310 miles range
252 wh/mi on AWD works out to around 295 miles range
I would expect that line to move to around 230 wh/mi if your range is now officially 325
You can take a close up photo and count pixels and do the math or try driving at around 230 wh/mi and your current average should be drawn directly on top of the reference line.
I updated last night to 2019.5.15. The car was charged at 90%, showing 277 miles before the update and still shows 277 miles after the update.
RWD LR
I wonder what’s causing the inconsistency here.
Same -- No range increase yet on LR RWD. Bizarre.
RWD LR
I always charge to 80% when at work which gets me 248 to 250 miles. Yesterday when I left work it was at 260 miles, which would translate to a 325 mile range. This was running on version 2018.50.6. Then last night I got the prompt and updated the car to 2019.5.15. So it looks to me like the range increase is NOT tied to a SW update, it's some other transparent over the air update. No idea if the power boost comes at the same time.
