Giving the fact that M3P with bigger battery than long range has less range because of the difference in motor, is it possible that a M3LR after AB upgrade would get less range than M3LR without AB since the AB causes higher power output?
Note: This feature currently requires accessing the site using the built-in Safari browser.
This.I’ve had it for 20 months now and don’t see any difference unless you use the extra power and have a heavy foot. Which I may add AB tends to unleash in most lol
ABoost obviously means one can use the extra power on demand…and I’d assume most do or why else buy it?
So to answer your question max range does not decrease but usable range May depending on how much you enjoy it![]()
No. And your supposition of a range loss and a battery difference between performance and long range are also both wrong. Last but not least in your misreporting of these issues, on earlier cars there was not even a difference in motors between long range and performance. That did materialize in the rear motor in later model 3s but for the first two years they had the same motor just different software and inverter settings. The difference in range is thus strictly from tires and wheels. Larger diameter Wheels cause significantly more turbulence and therefore are aerodynamically more wasteful particularly compared to the aero covers on the 18-in wheels. Tires on the 18-in wheels are also lower rolling resistance. All of that adds up to a significant range penalty for the performance cars.Giving the fact that M3P with bigger battery than long range has less range because of the difference in motor, is it possible that a M3LR after AB upgrade would get less range than M3LR without AB since the AB causes higher power output?
He’s correct. I have a 22’ LR/boost with 20” v1 oem rims and ASeason tires and I can tell my range hit is approx 10%-12% over the 18’s.No. And your supposition of a range loss and a battery difference between performance and long range are also both wrong. The difference in range is strictly from tires and wheels. Larger diameter Wheels cause significantly more turbulence and therefore are aerodynamically more wasteful particularly compared to the aero covers on the 18-in wheels. Tires on the 18-in wheels are also lower rolling resistance. All of that adds up to a significant range penalty for the performance cars.
That's about what other sources have quoted and measured. It was initially amazing to me that the wheels and tires made this much difference but it is what it is!He’s correct. I have a 22’ LR/boost with 20” v1 oem rims and ASeason tires and I can tell my range hit is approx 10%-12% over the 18’s.
Assuming you mean the acceleration boost?Made no difference for me
That's true but there had been a lot of discussion in the previous posts about different tire sizes so it wasn't clear which you were referencing.Yes that is the topic of this thread
I have a 2018 LR dual motor with the boost.Giving the fact that M3P with bigger battery than long range has less range because of the difference in motor, is it possible that a M3LR after AB upgrade would get less range than M3LR without AB since the AB causes higher power output?
It is true now for US market since Performance retains the ~82kWh Panasonic battery and the LR has the ~79kWh LG battery.
M3P and LR have the same 82.1 KWh battery. If you don't ask the car for more power it won't give you more power. Acceleration Boost only affects efficiency because you can ask the car to go faster than you could without it. Your right foot controls efficiency more than any other parameter.Giving the fact that M3P with bigger battery than long range has less range because of the difference in motor, is it possible that a M3LR after AB upgrade would get less range than M3LR without AB since the AB causes higher power output?
Unlike ICE, efficiency doesn't crater under hard acceleration- it goes down some due to increased heat losses, but nothing like ICE which reaches its peak modest efficiency only under max load (top gear). In lower gears, ICE is staggeringly wasteful, part of the big efficiency difference between the two types of powertrain.M3P and LR have the same 82.1 KWh battery. If you don't ask the car for more power it won't give you more power. Acceleration Boost only affects efficiency because you can ask the car to go faster than you could without it. Your right foot controls efficiency more than any other parameter.
