See photos. Should the second slave charger be on the left seat side, where there currently is an empty space?
No, that isn't dual chargers. But dual chargers aren't even an option for that vehicle. (You can't add a slave charger to the newer cars.)
You have a never vehicle and it can come with either a 48A or a 72A charger, and that one is clearly labeled a 48A variant. (The older cars had either one or two 40A chargers, so with dual chargers you could charge at up to 80A.)
Don't feel bad... I have a few loose too.There's a marble rolling around
Yeah, definitely, @rjscoder could you list the month and year of your car? That would make this much easier. Because it layout kind of looks to me like it would be a single out of dual chargers, but the label on the one says it's 48A, which would seem to indicate it's not, so I'm just a little lost.OP maybe helpful to list car ...duals went away when refresh came u either got a 48 or 72 ..some early one had software upgradeable 48s
Actually, dead simple answer is this: Does your car have the new updated facelift "nose" or not? If it's pre-facelift, then it had the single/dual. If it's post-facelift, then they had switched to the 48/72 one only chargers.
Enough about the chargers... how easy is it to lift the rear seat, as you've done there. Is there a trick? (I haven't even tried yet).
There's a marble rolling around under the rear seat and is starting to drive me nuts clinking around.
Well there ya go then. That's the same month and year as mine. That is the single/dual 40A chargers. I'm a little mystified at the 48 number then. Maybe the old ones were a little overbuilt and not running at their max level?Manufactured: 03/2014. It has the nose cone, pre facelift. So how do I have the 48? My console only allows 40 AMP max, is this a mistake, and it should instead be 80?
No I haven't--never had any reason to, but that would be interesting to see. I may do some experimental pulling on my seats to see if I can open that up.Have you checked whether yours says 48A on it?
Please do. Took me all of 5 seconds to pull it upNo I haven't--never had any reason to, but that would be interesting to see. I may do some experimental pulling on my seats to see if I can open that up.
All right, I went out at lunch, so I went ahead and pulled up my back seat. Side note for people doing this: pull up on the front edge of the seat. From one of your pictures, I had the impression it came up from the back, and I pulled on that for a bit with no success.Please do. Took me all of 5 seconds to pull it up
So mine is from March 2014, and I know it is the single 40A charger. It looks exactly like yours does in every detail. The single charger is under that back right seat, and the empty space under the back left. And yes, I looked at several of the key things from the label:
ASY CHRGR GEN2
And for INPUT, it does say 48A RMS
So I'll bring it back to your original post to find out what question you were trying to ask. You had some PDF of a service bulletin, which I did try to read through, and it looked like the description of the job to add the second charger. Is that all you are asking? You just want to find out if you can get the second charger added to your car? If so, then that is definitely yes.
Call 877 798 3752, they will look up vin , settle the question.
They emailed me the original window sticker.
Its cool to have the window sticker.
