JohnnyG
Weee!
I'm okay with not being able to change it in the car... that's exactly how the Valet & Speed Limit PINs are setup. However, the Valet & Speed Limit PINs are able to be reset within the app, without going through the in-car process for forgetting your PIN.Initially I thought the same, why can’t I change it in the car by entering the pin etc. However what if you let someone drive your car and they change the pin? I think forcing the full credentials in car is a good way to control the issue of unauthorized changing of the pin so only the account holder can change it.
I do agree it would be nice to have some kind of control on pin to drive in the app.
That said; I do agree that this PIN is particularly more sensitive, because if someone did screw with you, can can't drive the car... period.
At least with Valet & Speed Limit, you could still drive the car; albeit in a limited fashion.
With that, I do agree that maybe it should be locked down by the user credentials.
I would think that all three of these PINs should be able to be set / reset / cleared from our MyTesla page.
