Electric Vehicle Technology Roadmap And grid integration April 27th, 2011 JB Straubel
Discussion in 'News' started by emq, Dec 2, 2011.
Tags:
  1. emq
    emq Member
    Zürich
  2. jcstp
    jcstp Active Member
    Belgium
    verry interesting!
  3. Todd Burch
    Todd Burch Voltage makes me tingle.
    Smithfield, VA
    That last slide shows energy losses with tires almost as large as aero with highway driving. That surprises me.
  4. Eberhard
    Eberhard #421 Model S #S32
    Germany
    but you see, that the losses with the tires are almost constant, but aero goes up with square of speed
  5. Todd Burch
    Smithfield, VA
    Which is exactly why it surprises me that even at highway speeds tire losses aren't significantly less than aero losses.
    They must have used 55mph as their highway speed--relatively slow in the real world.
  6. ChadS
    ChadS Petroleum is for sissies
    I'm still trying to sort some of that out, too. The information presented seems to be similar to what's in the third chart in this blog: Roadster Efficiency and Range | Blog | Tesla Motors
    The aero drag does seem to be about what that chart shows for 55mph. But the tire friction seems notably higher at either speed. Drivetrain seems a little higher (if you add all the pieces together in the older chart). Maybe it's updated for Model S instead of the Roadster?
    What really puzzles me is the HVAC. Why is wh/mi less for city than highway? If they HVAC output is set the same (maybe that's a bad assumption?) you'll use more energy per mile at lower speeds, but the chart shows the opposite.
  7. TEG
    TEG TMC Moderator
    HVAC also used to cool the battery pack which otherwise gets hot during high power output?
  8. dpeilow
    dpeilow Moderator
    Winchester, UK
    Nice to see Martin's 2.8kW / 1 car slide in there. I aways like to drop that one on the skeptics.
    In the souyth of England it is closer to 3.6kW / 1 car but still totally doable.
  9. ggr
    ggr Roadster R80 537, SigS P85 29, M3P 80k
    San Diego, CA
    My understanding is that the city cycle involves a fair amount of accelerating and braking. While you do recover energy through regeneration instead of braking, there is an unavoidable loss each time you do it. The absolute best mileage is when crawling along in traffic that's doing about 20 mph but doing it steadily.
  10. tdelta1000
    tdelta1000 Active Member
    South Florida
    #10 tdelta1000, Dec 5, 2011
    http://iee.ucsb.edu/files/16Straubel.pdf
    The link provided more insight into the mad minds at Tesla Motors. I think TM has a really good grasp on its goals for the current product line and the futre offerings.
    BTW, thanks for sharing the link.... if only those guys across the pond would give credit where it's due. Sorry for the sidebar.:cool:
  11. VolkerP
    VolkerP EU Model S P-37
    Germany
    The "grid integration" aspect is just 1 slide... I hoped for more as I read into the presentation... :confused:
    Where is the TM wallbox with V2G uplink announcement?
  12. mpt
    mpt Electrics are back
    Warren, New Jersey, United States
    Anyone have any comparative data on tire choice? I just swapped the rears for 225/45R-17 Michelin Primacy MX. They claim lower rolling resistance but what does that mean?
  13. Doug_G
    Doug_G Lead Moderator
    Ottawa, Canada
    It means they are very resistant to rolling.
  14. TEG
    TEG TMC Moderator
    Huh? The opposite... They roll more easily. I don't know if either of you are joking.
    The stock Yokohama tires were considered low(ish) rolling resistance, so I don't know if the new ones would be any better.
    Rolling resistance contributes to wh/mi efficiency and maximum range per charge.
  15. Doug_G
    Ottawa, Canada
    For the record, let me state: :tongue:
    In all seriousness, I have compared long trip power consumption between Yokohama AD07 and Toyo T1R and didn't find any detectable difference. Purportedly the AD07 has low rolling resistance but the T1R's were just as good.
  16. William13
    William13 Active Member
    South Bend
    I have been looking at tires recently and the difference between a manufacturer's standard tire and higher efficiency tire is less than one percent milage difference. This would not be easily measured by an individual. I am not sure that it should impact a individual's tire choice unless every thing else is equal.
  17. VolkerP
    Germany
    There are already Roadster tire threads here and there so please don't turn this thread into another one.
  18. neroden
    neroden Model S Owner and Frustrated Tesla Fan
    Ithaca, NY, USA
    Here's the thing: low rolling resistance generally means poor traction, apart from minor tread design choices and whatnot. So the tire losses in that chart from Mr. Straubel are pretty much inevitable.
    Only way to really avoid that is to put the car on rails, but then it's a train :)
