AlanSubie4Life
Efficiency Obsessed Member
It is true if it happens 1 out of 1000 attempts, to each destination.What can't others hear this?
Elon Musk Quote: "But the car will be able to take you from your home to work, to a friends house, to the grocery store, um without you touching the wheel".
It can't be done now because of Wheel Torque required, even in 1 million attempts. So at the VERY least the Nag MUST be removed in 69.3.It is true if it happens 1 out of 1000 attempts, to each destination.
This is based on Elon's latest statements in the investor conference, saying no one needed in the car by end of next year. It makes sense to me since Elon is the one stating it... stop with the L3 and L4 nonsense. ...
That’s a little harsh.It can't be done now because of Wheel Torque required, even in 1 million attempts. So at the VERY least the Nag MUST be removed in 69.3.
I think the torque requirement makes drivers less safe. Precious time and attention spent keeping the system happy rather than focusing on what the car is actually doing. At a *minimum* they should remove it for vehicles with the interior camera.Agreed though they would have to remove the torque sense. Seems fine, even if not a good idea to remove your hands. Attention sensing might be good enough. Maybe they’ll get even better at detecting the glances down.
Initially this might be true. But then you just use it and there are no problems. Just a learning curve.Precious time and attention spent keeping the system happy rather than focusing on what the car is actually doing.
I have been using AP since 2018 and FSDb for over a year. It is still more of a distraction than an actual safety feature.Initially this might be true. But then you just use it and there are no problems. Just a learning curve.
See here if you missed the memo: Elon: FSD Beta tweets
Fool me once, shame on you.
Fool me 2,763 times…
I mean it is hard to test the counter factual. Maybe we will soon though!I have been using AP since 2018 and FSDb for over a year. It is still more of a distraction than an actual safety feature.
The "March of 9's" is specifically a rate of SAEFTY-related failures/disengagement, not TOTAL fails, isn't it?I don't consider the situations where it currently fails 'the march of 9s'. I had two very good drives to and from work today, but also had two failures:
Link to the recent study?A recent study found hands-off systems produce measurably less safe results than hands-on ones--- so your thinking does not appear to reflect the real world outcome.
The only way I see them remove the hands-on requirement is when they think the intervention need is so low as to make that a non issue.
The interior camera can not do the same job the torque sensor can- especially given it was never intended for that work and thus it's both the wrong type of camera, and located in the wrong place.
He clarified this in the followup question.Elon Musk Quote: "But the car will be able to take you from your home to work, to a friends house, to the grocery store, um without you touching the wheel".
Regardless, the torque sensor does not require you to keep your hands on the wheel. It requires you to tug the wheel at irregular intervals.
