Tim Alguire
I noticed on the Canadian CPO model S changed over night only 12 listings... that is less than the Tesla CPO Site. Where did they all go?
Hi,
One problem, I'm UK based and there's a special field labelled 'Display only VAT Reclaimable Cars (Applies to Europe CPO Only)'
Not sure if this means I'm missing any alerts but reducing the results from 82 to 5 you can see it might be an issue.
Ok, this is fixed. It was just a small bug in the interface. You'll need to reload the page once to get the update.
The Alerts are all working as expected. You can tell because each configuration returns the correct number of matches on the "Configuration Garage" page, so that means the alerts are working.
Thanks for the heads-up.
HLR....curious whether it's the same VINs being pushed first for updates? And whether they are updated manually or via a token? If there were any patterns, I suspect you are best positioned to detect them with your sample size.
TIA
For the first question, I've never looked at if there are VINs that are always updated earlier than others, that would take some time to figure out. The full dataset is available for download if anyone else wants to take a stab at that, I'm just too busy this month to do a deep analysis.
Thanks for your note. The relistings are a side-effect of how Tesla lists their cars in Europe. Overnight, almost every night, a lot of cars are removed from the listings, which EV-CPO picks up as sold or removed. Then a few hours later, they are "relisted" again, which EV-CPO then picks up as, of course, "relisted" and sends out alerts for these cars. I had modified the system so alerts only go out once per day per car, so if these cars are removed and relisted the same day, multiple alerts are not sent out (this was a problem when several cars were simultaneously listed in multiple countries). I understand the daily alert that goes out with lots of "relisted" cars is often redundant, but I can't really tell the difference between cars quickly relisted, and maybe other cars that were removed previously and then actually relisted for sale. I'll look into adding a delay so cars that were delisted don't trigger new alerts within a set period of time. Sorry for the inconvenience.
Since you are tracking delisting, is it reasonable to add a date/time in your data set for when it was delisted, then only send e-mails if the relisting time is > some amount, or< amount and price decrease?
Yes, I said above: "I'll look into adding a delay so cars that were delisted don't trigger new alerts within a set period of time."
