Here is my mid year post if you want to use it as a guide: Evie EV charging networksHow many 350kW chargers does that leave Evie to open to complete the original funding?
Toowoomba (North Point shopping centre) and Canberra (BP Kingston) both have sites announced.Here is my mid year post if you want to use it as a guide: Evie EV charging networks
I may have missed some, but the only updated ones from memory are Bolivar, Epping, Ballarat (Warrenheip).
Canberra is severely lacking anything greater than 100 kW that isn't Tesla.Canberra
50kWCanberra is severely lacking anything greater than 100 kW that isn't Tesla.
And new 2 stall site at Raglan St Mosman showing as online.
Man, they are pumping them out at the moment! I’ve lost count of how many that is over the past month, with more to come they say.
Somewhat confusing setup in the app with HS002 and HS002B each with four connectors (two CCS2 and two CHAdeMO)
Plugshare does get a live feed of site status from Evie (Google Maps seems to get a live feed from both Evie and Chargefox).I'm doubtful that Plugshare is somewhat connected to Evie backend..
Actually yes you're right. I was comparing that Evie site with Karuah which obviously is Chargefox!Plugshare does get a live feed of site status from Evie
Note that the "Out of order" on the CHAdeMO plugs is actually just "this plug can't be used right now because the corresponding CCS2 plug is in use".
Yes. It appears to be a limitation of the OCPP1.6 standard - it specifies only these status codes for connectors: Available, Preparing, Charging, SuspendedEVSE, SuspendedEV, Finishing, Reserved, Unavailable, Faulted. The first 7 indicate the port is "operative" and the last two "inoperative".Which is really terrible UI messaging. Someone with a CHAdeMO car (or CCS2, if someone was plugged in with CHAdeMO) will think “oh crap I need to find another charger somewhere else” not “hopefully by the time I get there it will be avaliable”.
