stopcrazypp
Lol, you were wrong about 3-5 miles tops, even using your cherry picked stations. This is putting aside the point that is already more than the ~2 miles you suggested earlier before factoring in charging stops. I just put examples from the default routes from two charging planning apps (including the one you used), and they involved a lot more off highway travel than you let on. And even in the article you linked, it suggests to use more stops rather than skipping. Skipping actually takes a lot longer.Its over. its done.
Its 7.6 miles, deal with it. About the same miles/stops others have traveled while doing cross country.
“It will do this without the need for a single touch, including the charger,” says Musk.
Elon directly contradicts you. unless in this case Elon statement doesn't amount to anything cause it doesn't fit your agenda? That won't be surprising would it? you have a knock at attempting to twist things to look your way.
But we both know that we will know very easily the route that tesla takes by looking at which supercharger is automated.
its over man, you were wrong. let it go...
As for the snake chargers, I did not initially focus on that part of his trip promise. Although he says the driver does not have to touch the charger, he did not say it necessarily has to be snake chargers or some kind of robotic solution. Tesla had supercharger valets since a year back at busy locations. They can have similar for the trip if it comes to it. This would be similar to some states that require an attendant at gas pumps.
Tesla Supercharger Valet Service In Action - Video
