SDRick
Thanks.. I did the same thing, but I live in Florida and have a E-pass. I guess it isn't quite a strong.
If that works, I would spray paint that thing black.
Here you go:
I'm the person who started this thread. The Natick, MA EZ-Pass center gave me a new smaller transponder with a fresh battery. To ensure that I'm doing a scientific test of the mounting, I have reverted to mounting my new transponder in the area to the right of the rear view mirror with the arrows up as shown. About 1/3 of the transponder hangs past the black area, but I figure this will provide me with a good baseline test.
I've only had the transponder scanned once so far, but it scanned successfully that time. More data as I collect it.
I mounted mine horizontally because others have reported success doing so, and I think it looks a bit better. If it fails, I'll try vertically, and then move to rear panel and rear window mounting. But I want to gather data on the success rate in each position to better gauge the performance of each location.Why did you mount horizontal, not vertical?
Thanks for the trial, and keep us updated! That seems like the logical location, and perhaps the "black area" will get larger on future models, since the EZ Pass is fairly standard!I'm the person who started this thread. The Natick, MA EZ-Pass center gave me a new smaller transponder with a fresh battery. To ensure that I'm doing a scientific test of the mounting, I have reverted to mounting my new transponder in the area to the right of the rear view mirror with the arrows up as shown. About 1/3 of the transponder hangs past the black area, but I figure this will provide me with a good baseline test.
If anybody is interested. Here's a E-ZPass taken apart. The parts are horizontally aligned.
If you are looking at the E-ZPass from the front (where the barcode/label is) note that the antenna part is on the right. So when you mount it make sure the right part of the E-ZPass is on the non-coated section of the windshield.
Disclaimer, I'm no expert on EM systems or radios, I just like to read a lot.
According to various documents on the Internet (http://www.root.org/talks/BH2008_HackingTollSystems.pdf), it seems that the E-ZPass transponder is vertically polarized (perpendicular to the surface of the Earth). So while mounting the E-ZPass sideways (vertically) may work, it is probably better to mount it horizontally. Or in Tesla's case, upside down with the right over the black non-coated area.
Additionally, the communication protocol for the transponder systems seems to be governed by something called "Title 21". The toll booth antenna sends a carrier signal to your transponder. And if the antenna of your transponder is in a position to receive it, it will modulate (backscatter) the a hardcoded frame back. This can take up to 1s on normal toll booths (not the express ones). While this may sound like its quick, the Tesla is quicker.
With that said, I did all this research to see if I can come up with a more elegant way to mount a transponder than a) on the winshield b) on the bumper c) taking apart a nosecone on the refresh by going through the frunk d) mounting in the rear trunk. (Mounting on the front will allow earlier detection aka less slow down at the booth, thusly less "unable to read" anxiety.)
My current idea is to create some sort of sticker antenna that I can mount on the non-coated part, and paint it black. With the chip/transistors hidden away inside the rearview/autopilot cradle. It'll likely fail, but should be a fun project/learning experience nonetheless.
When I picked up, my DS told me to mount it directly under the rear view mirror. He said it is the only place that seems to work consistently, every where else is different degrees of readability.
I bought a couple toggle bolts at the hardware store and mounted the black EZ Pass transponder in the black grill to the right of the radar (drivers's side). The EZPass has worked well in Maine, NH, MA, NY, NJ, PA, and VA. Most folks don't notice it. Do you?
I'm very happy I don't have the transponder cluttering up my windshield or my license plate.
Would you kindly be able to post a picture of how/where you hung your EZ-Pass transponder? I tried directly under the rear view mirror, but does not seem to work consistently. Thanks!!
I live in a gated community that uses transponders to open them. I have a P90D refreshed model. So far the only solution I have is opening the sunroof and holding the darn thing in the air. I share your interest in an answer to this one.
Sorry to revive an old thread, but wanted to see if you've been happy these past few months of driving, having mounted your new EZ Pass horizontally (with some of it sticking out of the black area)?I'm the person who started this thread. The Natick, MA EZ-Pass center gave me a new smaller transponder with a fresh battery. To ensure that I'm doing a scientific test of the mounting, I have reverted to mounting my new transponder in the area to the right of the rear view mirror with the arrows up as shown. About 1/3 of the transponder hangs past the black area, but I figure this will provide me with a good baseline test.
