Off Shore
Off Topic Member
Congratulations on your contract and best wishes for a successful run. Are you paid by the word or by the # of replies? Never mind, this is our last interaction.My point is that physics makes hydrogen advantageous on long haul, heavy vehicles against current battery technology. How many miles has Tesla said they'll get? The rumor is maybe 300 miles? How many kWh will it take for a 80,000lb truck and trailer combo to do 500+ miles? What about 1500 miles like some current long haul tractors? Protrerra just did 1100 miles with 660kWh in a lighter vehicle at probably some sort of optimum speed. That equals an efficiency of 1.67mi/kWh. Lets say the the semi does 1kWh/mi with an 80k travel weight. That would require 1500kWh of battery (with no buffer). Using 160Wh/kg pack level mass density (class leading right now), you're at 9,375kg (20,668 lbs) just for the battery pack. That doesn't include the cab, electric motor assemblies, or all the drivetrain and other things. Current Volvo tractors weigh 13k to 18k pounds, which leaves room for 62k to 67k of payload. At best, that's likely dropped 52.5k or so with a long haul BEV setup. Fuel cell setups do not suffer from the same linear increase in energy storage weight that BEVs do.
What does the charging distribution need to look like to handle a fleet of transport trucks? What's the point grid load on a station with a bunch of truck operators hooked up and charging at 500kW? Lets say you have 10 stalls like some of the Pilot stations I've seen. That's 5MW of continuous power. Dwell times for the trucks would be over 3 hours from empty.
