Debating about calling an electrician or doing a DIY NEMA 14-50 outlet installation (I don't want an electricain to pull one over me, so I want to make sure I have my bases covered).
The distance from the breaker box in the basement to the carport outside is about 50' feet. I'll be remodeling the basement soonish, so I'm not worried about ripping up some drywall, most of the cable run should be going through an exposed/unfinished part of the basement anyways.
99.9% of the wiring/etc. is indoors, I just need to drill a hole in the drywall and bricks to get the cable outdoors and install the outlet at exactly the location of the hole that I'm going to make (I'm not planning to use any conduit to run the outlet/enclosure to a separate location)
Now my questions:
1. I'm assuming that I'll need to use outdoor cable, even if everything is indoors and the only cable outdoors will be going straight into a waterproof enclosure (i.e. drill a hole in the brick, put enclosure over the hole, stick wire through and connect everything)?
If so, what kind of wire am I supposed to use (I believe it's 6/3 for the NEMA 14-50), can I use UF-B or do I need THWN for outdoors?
2. Can I use this as my enclosure/outlet:
http://www.homedepot.com/p/GE-50-Am...gclid=CI-m2uaP6sYCFcESHwodwqAMjQ&gclsrc=aw.ds
3. I have a 200A service panel, and plenty of room for an added 50A circuit. Is there anything I need to be concerned about here? (I can do a load calculation if it's required to get the permits, but I'm positive that I have enough load capacity to add a 50A circuit)
Am I missing anything?
Looking at costs
-Permits ($108)
-Wire $200 ($4/ft UF-B)
-Enclosure ($30)
-Circuit breaker ($25)
If I can get an electrician to come in under $600 - perfect, otherwise I think I'll do it myself (should be a 2-3 hour job).
