Far West Texas Charging
Discussion in 'Texas' started by charliepmayer, Mar 16, 2018.
  1. LCR1
    LCR1 Active Member
    Houston
    Isn't it just a resistor that the car uses to determine what the allowable amps are?
  2. BerTX
    BerTX Supporting Member
    Texas/Washington
    There are only 25 sites with electricity in the park. They are reservable, and usually are all reserved very far in advance. If there is any chance you will need to rely on this, you'd better call.
    RV Camping - Big Bend National Park (U.S. National Park Service)
  3. tmoz
    tmoz S85D, Prius PiP
    Gilbert, Arizona
    Yes indeed - they are available. I must have been looking when it was incorrectly thought that Tesla was going to discontinue this adapter. I would definitely get the adapter straight from Tesla, had I known they were just restocking. Probably cheaper than what I paid. I may just go get one anyway.
  4. PLUS EV
    PLUS EV Running on Empty
    Seattle
    Most RV parks have both 30 amp and 50 amp. So be sure you get the 50 amp outlet.
  5. tmoz
    Gilbert, Arizona
    Because as we know, "More is better". (-:
  6. PLUS EV
    Seattle
    Actually I was more concerned that he would blow up the breaker on a 30 amp as I have heard such horror stories on these forums. No experience myself fortunately.
  7. tmoz
    Gilbert, Arizona
    Good point.
  8. BerTX
    Texas/Washington
    We ALL need to keep in mind that the breakers in RV parks are old and overworked. Compounding the problem (probably) is that they are being used as switches to turn power on and off several times a day, which possibly wears them out faster.
    Good practice on any RV outlet is to start the amperage setting low and ramp up. They work by tripping when they overheat, so once you have overheated them they tend to be more sensitive. Yes the homemade TT-30 adapters should be manually limited to 24 Amps, but don't start there...
  9. rideincircles
    rideincircles Member
    Fort Worth, Texas
    Great road trip as usual out to Big Bend, but I had to leave my car in the Chisos most of the weekend and we had to cram 4 people in a Tiburon to travel around since charging was too much trouble for getting around the park this trip. Here a few things I kept track of from my trip. For reference I have a LR RWD Model 3 which maxes out at 325 miles of range. Any mileage figures is based on my car.
    I used up 170 miles of range to get to the Chisos Basin campgrounds from the Fort Stockton supercharger. On the way back I used up 146 miles of range to get back. This pretty much uses up the battery completely once you factor in overnight mileage losses. I charged to 317 miles at Fort Stockton. I also was pretty much driving the speed limit in chill mode the whole time and sometimes went 5 over. I had the A/C off cruising around the park from the Chisos to Rio Grande and back, but turned it on leaving the park.
    The Rio Grande RV spots is the only place to charge in the park as stated other than using a 120v outlet if you are staying in the Chisos lodge. I did not see any other options around the park. Any other charging has to be done outside the park at other RV campgrounds. I stopped by the Rio Grande RV spots to charge for 3 hours and the employee let me slide on charging a few hours, but otherwise the day use fee is $35 and it was booked overnight so it unreliable unless you reserve a spot in advance. I cleaned up trash from in the bushes around the campgrounds while charging so that was my trade-off for a few hours of charging. If you want to drive around in the park, then this is the only option to charge and stay in the park as of now. Period. $35 a night.
    Going from the Chisos campgrounds to the RV charger used up 4 miles of range since it was all downhill, and used 51 miles going back. I added 30 miles of range for my drive back after factoring there and back which was enough to get back to Fort Stockton.
    Cruising around on autopilot in the park works great. I am guessing it may have some issues heading to Santa Elena Canyon on the roads, and I took over for the sharp turns in the Chisos, but on the main roads it works great. I did not get the recent NOA update before my trip. Autopilot is limited to the 45mph speed limit or 5 over in the areas I checked in the park. No biggie since you have to be the most efficient you can here.
    I talked to quite a few people who work at the park about EV charging, the best option they said would be to fill out the comment form and request EV charging since it goes to the superintendent. Realistically this still may take forever, so the better option may be to contact the lodge and RV campground owners and request EV charging access. Having an hourly rate to charge would be ideal, or a day use EV charging pass. I sent an email to the lodge about it and filled out the comment form.
    That is all the main points for now that I can think of. I did see another Tesla Model s 75D in the park and I know they spent one evening in the RV spot charging and passed me up on the way out. As of now, big Bend is one of the toughest places to take an EV. IT can be done, but you have to plan around it accordingly. Hopefully my friend in Terlingua sets up a Destination Charger soon, since that would make the trip much easier to deal with, but we still need more options out there that do not requires staying overnight in a campground outside of the park. Otherwise I will still go back as often as possible, but may hold off on the Chisos campgrounds next time.
    • Informative x 6
  10. charliepmayer
    charliepmayer Member
    Texas
    Anybody still interested in a rally in August?
    Proposed itinerary below.
    Lodging: Hotel Limpia, Paisano Hotel, Holland Hotel, El Cosmico, Cibolo Creek Ranch, Maverick Inn.
    You pick. Don't think we can get enough people at a single hotel, but if we do we can get a group rate.
    Drinks and dinner at Hotel Limpia on Friday, August 16
    Breakfast buffet at the Blue Mountain Bistro on Saturday, August 17, 7:30-10:00
    10:00 - Tour of the Fort Davis National Historic Site on Saturday, August 17
    Saturday afternoon: on your own for scenic drives and other activities until dinner
    8:00 - Cocktails and dinner at the Century Bar & Grill in the Holland Hotel - Alpine on Saturday, August 17
    Sunday: on your own for scenic drives and other activities until dinner
    5:00 - Cocktails and dinner at Jett's Grill in the Hotel Paisano - Marfa on Sunday, August 18
  11. charliepmayer
    Texas
    No responses on any forum - so I'll just turn this over to individuals that want to come out.
    I'll be out there in August - perhaps we can meet up.
  12. ACExpress
    ACExpress Member
    Dallas, TX
    Thanks for posting. I just returned from Big Bend, and your post was helpful.
    I was coming in from Dallas with a Model S 75D, and I charged to 221 miles at Fort Stockton. Driving somewhat conservatively, I arrived at Chisos Lodge with 48 miles of range. While staying at the lodge, I was hopeful I’d be able to plug into the 120v outlet over 2-3 days to give me enough charge to get back to Fort Stockton, but I couldn’t find anywhere around the Chisos Basin lodging area (visitors center, store, lodge, etc.) that would reach with my standard charging cable. I asked the front desk for an extension cord, but the one they were able to procure from maintenance was only 2 prong and not the NEMA 5-15. My car displayed “charging equipment failure” when plugged in.
    Unfortunately I headed to Rio Grande Village on my last afternoon and needed to charge for 7-8 hours to have enough to get back to Chisos and then Fort Stockton. No cell service in Rio Grande Village, and it was predictably scorching hot. Probably the low light of the trip. It only took me 2 rated miles to go the 26 miles from Chisos to Rio Grande Village but took about 55 miles going back. It did afford me the pleasure of seeing my last 30 miles wh/mi go into the negative.
    I am not positive had I brought a proper extension cord that it would’ve worked at Chisos, but I will make sure I have one in the car going forward. Outside of the bad charging situation in the area, it was a pretty easy trip from and to Dallas.
    • Informative x 2
