GDH
Banned
You turned the setting on, correct? I believe it was off at delivery for me...
multiple times. I will probably take it back to the SC next week.
That concerns me. Although I have yet to receive ver 5.6, the rated range calculation should be a constant that only takes in consideration what the EPA rates as the expected watts used per mile in an average temp day at average driving speeds.
Has anyone noticed that supercharger charges no longer seem to get added to the visited chargers list? I charged at my first SC under 4.5 and it was added to this list. But today, my charge at the new Rocky Mount charger under 5.6 was not.
I've always lost around 7 or 8 miles overnight... Since day 1Anyone losing this type of miles to vampire drain needs to contact a service center or 'owner experience' to troubleshoot the problem. My garage temp last night was about 45 degrees. My charge was 219 at 8pm and 219 at 7am this AM. My experience with 5.6 vampire loss is max of 3 miles in 24 hours when sitting.
Things that may help.
1. Key fobs 20+ feet away from the vehicle (mine is 10 feet but separated by a metal door). Close phone app/ipad app, etc.
2. Reboot the 17" screen
I've always lost around 7 or 8 miles overnight... Since day 1![]()
All, we went through this very same stuff last year when it got cold.
Couple of issue that I have had in 24 hours.
Charge port not releasing charger
Tilt mirrors not tilting
Door handles not presenting
No beep with parking sensors
Car rolls forward and backwards at a stop (creep is off)
Since I have only had the car for 24 hours some of these things might be normal but the charge port not releasing is a concern.
If your car is parked in cold conditions (near freezing and above), you may see a drop of 7-9 miles rated overnight. But that it primarily because the pack his been cold soaked, so the apparent SOC as seen by Tesla's algorithms is lower. The vast majority of that is not real range loss. As you drive and the pack warms up, some of it comes back.
Remember the wonderful Broder incident? He came out to a cold car, panicked at the range loss, and turned on the climate control to heat up the pack and get range back. That was his major mistake. You don't turn on the heater and expect it to add energy to the pack (Duh)! He should have just started driving, and as the pack warmed up, some of the apparent range would have returned. I think many of you are seeing the same effect.
I've repeated it in several threads now. A good tesla source (Walter Frank) has indicated that the car does not actively heat the pack unless it's REALLY cold (sub 20°F?)
Charge port: car must be unlocked to release cable. Ensure the car senses your FOB before attempting to unplug.
Tilt mirrors: put car in reverse to set the tilt positions.
Door handles not presenting: ensure the option is on in the settings. Also, if the car hasn't seen the fob for 24+ hrs, you have to unlock manually using the fob.
Car rolling forward and backward at a stop (creep off): this is expected behavior, is it not?
My 8 mile average range loss in a 12 hour overnight span is all in a 60+ degree F garage.
So it's not a battery cold soak issue... even with 5.6 my car is consuming unreasonable amount of idle power (200-250W). I'll give it one more week to see if I can ever get sleep mode to work, then contact Tesla if not.
Shouldn't the mirrors simply tilt as soon as the car is put in reverse?, I was not told I had to do anything else than put the car in reverse.
Car rolling, not sure my Volvo did not roll when it was in drive....that might be a Tesla thing.....still new to the car!
All else I get.
Ok got it, thanks!.....you've been very helpful!
Hi! We've only seen temps that low the last few nights. Usually it doesn't get below low 70's at night. I don't pay much attention to overnight losses anymore, so I'll start tracking it just to see if anything changes with the weather. I've become so used to driving electric now all range anxiety is gone. I just plug in when I get home, unplug and go in the morning without looking, really. I sort of checked it the first couple of days after getting 5.6 and was still losing about the same, though.Blue girl: Long time no talk! My experience is so different than many of the people here regarding 5.6. With 4.5 I lost between 6-10 miles overnight (12 hour period). With 5.6 I am down to 1-2. Not sure why there is such a difference. Since your 'Location' indicates Florida I would assume you are still in the 50-60 degree range at night?
Speculation: In other 5.6 news, I called yesterday and Ownership said they're still pushing 5.6, but obviously there's little evidence of that here. I suspect they're implementing some rolling fixes and will send an updated build to the remaining folks...then go back and push the updated build to those who already have 5.6. Again, just my hunch.
