Test results:
1. Dcdc signal plug disconnected, pin 5 and 6 are connected together separately from the plug. Cover from HV connectors removed. When 12V* battery was connected i saw 140-180V on each of two HV wires. However NO Charge to the 12V battery.
2. When I put pin 5 and 6 back in the connected and pin 1 and 2 disconnected from dcdc, i dont get any voltage on HV. The voltage on pin 4 at this time is around 120mV which is very low. So I apply 11.3V to the pin 4 with 12V battery connected i still dont get any voltage on HV Wires. This pretty much simulates the test that Ingineer performed, but it fails on my car when installed. However I dobt hear contacts closed when pin 1 and 2 are out.
3. After installing all pins back together the HV contractors never closed and NO Voltage on pin 4 either.
I have no idea what went wrong now.
