So the latest best bet from home depot is the short one from the package:
685447?
Everbilt 5/8 in. x 2-1/2 in. and 5/8 in. x 3-1/4 in. Zinc-Plated Extension Spring (4-pack)-16089 - The Home Depot
On the youtube comments, people are saying you have to replace the struts or else the spring is not strong enough to open the frunk. Has anyone found a stronger spring that allows for easy close but doesn't require you to replace the struts?
I know this is a noob question, but what tool did you use to cut the coils?Just installed a lighter spring, Prime-Line SP-9610, 5/8"(16mm) x 2.5"(6.4cm) x .072(1.8mm),19.1 lbs.
I cut 2.5 coils off to make the length similar to the original spring. It is definitely much easier to close and so far, consistently pops the frunk. I have not replaced the frunk struts.
Prime-Line Extension Spring 0.072 " X 5/8 " X 2-1/2 " Steel Polybag Of 2 49793096104 | eBay
My understanding is if you replaced the struts any spring would work.Will this work with the self opening struts? I put the stuts on from the i1Tesla video and found they don't always lift the frunk
Strange, even one strut from the i1 video should be able to open the frunk.Will this work with the self opening struts? I put the stuts on from the i1Tesla video and found they don't always lift the frunk
I wonder if I got knockoffs, I mean the part number and sticker looks the same, but I guess you never know these days.Strange, even one strut from the i1 video should be able to open the frunk.
Actually, it's a really good question. I used a compound wire cutting pliers that my Dad purchased decades ago. I might try long handled bolt cutters. It was a little tricky as I needed to cut a coil, separate it then cut the next coil. Bending the last one up also took a little work.I know this is a noob question, but what tool did you use to cut the coils?
I used the Prime SP-9610, I tested it "as-is" and it worked fine but I chose to cut 2.5 coils to make it the same length as the stock spring so it had a little more tension when unsprung.Can confirm Prime SP-9609 is the best for factory struts. Perfect for those that want a softer close and do not want auto-opening hoods!
I have been using the home Depot spring for about 2 months. I have stock struts.
And it pops up about 1cm. I like that I can close it more easily.
I watched the i1tesla video and am really tempted, but am concerned about the safety. Is there any conclusive determination on how safe it is long term? Why would Tesla engineers over engineer this piece of it wasn’t needed?
