CanadaCarCare
Tesla mentions the very specific lifting points in the manual, and there is probably a reason for it.
This is not unique to Tesla. Every manufacturer will reference the proper jacking points in the owners manual.
Given that you rotate tires without crisscrossing, you can jack up the car using the front jack point. The whole side will lift off the ground. Do so at your own risk. If not comfortable with this you will need two jacks.How do you proceed if you don't have a 5th spare wheel?
- Did you lift the whole car first?
- How and what did you use to lift the car?
With two jacks, it would be pretty easy.How do you proceed if you don't have a 5th spare wheel?
Yep. I thought I needed two jacks but I ended up swapping one tyre at a time so only one jack is required. People who only have one set of tyres that are on the car need two jacks for a rotation. Swaps are simpler and since it has to be done anyway in winter climates and the rotation is part of the swap.I rotate my tires twice a year when I switch over from winter<-->summer.
I put on Nokian WR-3G (now 4G) in the winter. These are severe service all season tires, that are as good as all but the very best winter tires. However, they don't just melt in warm weather. Summer I run the Primacies.But you don't put winter/snow/M+S tires on in the winter do you?
Do you run all-seasons or summer tires?
Use Jackpoint jack stands to lift one side. If you are rotating when swapping summer/winter, just lift one wheel at a time.How do you proceed if you don't have a 5th spare wheel?
As for the RakJack, it would be a lot more inconvenience than a simple manual jack for me. Maybe when I reach 80 years old ...
<<shrug>>Inconvenient? I'm the king of lazy, and it's 10x easier that using a regular jack.
There is, but it is only reinforced at the jack points.There is a continuous frame rail along each edge of the car....go on the net and look at the frame pictures.
The jack point is on the battery. The car has its own frame structure which is the rocker panel.There is, but it is only reinforced at the jack points.
Can you tell me how you rotate the tires at home? I have 2 Jackstands and 1 Jack and 1 Aftermarket Special Pad to put between the Tesla and the Jack.I rotate wheels at home and glad I don't have to deal with the stress.
Second that.
