FSD Beta 10.11.1 (2022.4.5.20) - Limited or Mass Release?
This release flow does seem to follow the drip-drip pattern from the previous one so far.
It appears that many drivers aren't aware that they have a pending update primarily because they are still asleep.
Lets see if there's a new cluster of pending updates (200+) in the middle of today. If not, this may turn out to be a limited rollout.
Reactions: SSDTester#1
FSD Beta 10.11.1 (2022.4.5.20) dropped and will likely take on the same path of its predecessor, with a limited release to US testers.
I don't understand why you started this thread with that assertion given there is no evidence, circumstancial or otherwise, that indicates the intended breadth of this release.
Care to share reason for your initial assertion and then doubling down on it a day later?
Every update has followed a few > pause > many > pause > most pattern. Yes, 10.8 & 10.10 had bugs that required incremental releases but they began the same, pausing before "most" to fix issues.
It will likely pause today. If it doesn't continue this evening or tomorrow there may be a bug. It is equally plausible to us here in the speculate-verse that the faucet will open within the next 24 hrs for all [beta enrollees].
