IIRC, 20.49.0 is when they started requiring logins. Subsequent versions have included that security feature.I had an older version (don't recall the version number), that version didn't require local logins.
It seems that some pages, but not all require a recent login. For example /api/meters/aggregates does, but /api/status does not.IIRC, 20.49.0 is when they started requiring logins. Subsequent versions have included that security feature.
@astrorob Are you sure some of the page elements aren’t being cached in your browser for the local interface and that is why you are still seeing the UI element for the off grid button?
My button went away with my downgrade.
I am still on new stuff. Now I have hardwired, no wifi, is this going to make a difference. Anyone who got pushed back hardwired?Pretty sure I can see why now, at least from my Gateway v2.
Take a look at the attached image, you can see that every 45 minutes or so the gateway is either losing its network connection and then rejoining or the gateway is restarting.
You can see the section where the software update/downgrade occurs and now all the lines are flat again. Looks like they've pulled it for some type of stability issue.
I have Ethernet, wifi and cellular and am still on 21.20.2, so maybe it was due to wifi stability issues.I am still on new stuff. Now I have hardwired, no wifi, is this going to make a difference. Anyone who got pushed back hardwired?
That seems to be one possible data point. I am also still on 21.20.2. Shall be interesting to see if anyone that got changed back has hardwireI have Ethernet, wifi and cellular and am still on 21.20.2, so maybe it was due to wifi stability issues.
10 points for meIm still on 21.20.2 as well. I also have my gateway hard wired to my network. Interesting observation there, about wired vs wifi. I do have the gateway setup for all three, like @MorrisonHiker does, but it prioritizes wired when you have a wired connection.
10 points for me![]()
Bingo we may have it.If you'd like another point my Powerwall is on 21.20.2 and its connected via ethernet.
booI have cabled Ethernet, wifi and cellular here in Sydney and was just changed back from 21.20.2 to 20.49.0
