ValueAnalyst
Closed
Obviously, I'm not @jbcarioca but I'll try to answer this great question anyway. Let's start by breaking it down first:
- Drive Units (RWD/AWD/ P):
At the moment Fremont is most likely QC'ing- and burning-in the front motor (AC induction) in one single production step. For RWD/P they not only have to do the same for the back motor (PPM) but also sort them by highest output. Overachievers will receive a second burn-in and will go into Ps, the rest will go into RWDs. Installing the front motor appears to be brain-dead simple: In layman's terms, the front drive unit only needs to be attached to the battery (2-4 cables) and the cooling circuit (2 tubes). Done. The only real question is, if they can pull of the installation of the front- and back DU in the same production step. Sourcing the front motors in adequate numbers is a non-problem in my eyes.
- Black & White interior (P):
We already know that the B&W interior is supply constrained. No additional complexity should be expected, as this is the identical, premium interior beside the color trim.
- Wheels & brakes (RWD/AWD/P):
Literally a matter of installing different sets of wheels and breaks.
- Carbon spoiler (P):
Most likely installed by the guys who're installing or QC'ing panel gaps. Should be a matter of seconds. No additional production step required.
Relative to the problems they're still facing with LR+PUP, I'll rate those at
- Overall (adding multiple options & trims):
- Difficulty: +1
- Productivity: -0.25 to -1 (at least in the first few quarters)
- Performance:
- Difficulty: +0.5 to +1
- RWD:
- Difficulty: +0 to +0.25
Thank you for the detailed response; much appreciated. That's probably a bit less complexity added to the production line than I would have thought based on @generalenthu's comments this morning. I'm looking forward to any other responses. Thanks again.
