I'm curious why there isn't version b software being published similar to the version e updates I see so often?
Here is the version B DSP softwareI'm curious why there isn't version b software being published similar to the version e updates I see so often?
Thanks! However, like the version E software, this one is also being detected as a virus by Microsoft Windows Antivirus (Defender). Is this a false detection?Here is the version B DSP software
Hansshow/Model-3-SR-Audio-Upgrade-Version-B-DSP-software
Sir, you may make a huge mistake, please google what is LPF means, low pass filter.
That means if you set it to 80hz, the subwoofer will only output Hz from 0-80Hz, you can also hear the sound under 40Hz, like 25 Hz.
Please ask a professional Stereo to get more information.
My friend was looking at buying this based on the 25% discount but my advice to him was to wait as there seem to be a lot of problems. Things like mixed up balance or fader in at least one review I saw would give me pause and if that part isn't correct there could also be other issues that are harder to notice like polarity. I suppose if you had the patience and skill, you can sort out these issues and start cutting wires and re-soldering them to get everything sorted properly. The other issue that I find questionable is in such a short time they have gone through 4 variations of subwoofers starting with a 10" MDF which got discontinued in a very short time and then replaced with an oval 5x8 which was claimed as improved, which is hard to believe (but not impossible I suppose), that its better than a 10" round for subwoofer duty. Shortly after there was an 8" round in an underseat style enclosure and now they've introduced their 4th sub enclosure. Are they engineering and developing that fast or just rushing things onto the market? I'd wait until the dust settles and also give time to see if there are other players with audio solutions. The advantage of the Hansshow stuff is the bracketing that can bolt up to the car easily but to answer your question either wait or buy name brand sub and get custom bracket made.Is this kit worth it? It seems like people are having a lot of issues, and I don’t want to be a guinea pig on a $500+ product.
What’s everyone’s thoughts on ordering the DIY kit, and then installing a brand name subwoofer along with it?
I finally got the DIY kit installed, however the rear speakers are swapped, left is right, right is left. Is there a fix for this? Everything up front is fine.
See the video here:
He's DIY harness only so he can't fix the issue except cutting and reconnecting the rear speaker wires to change this
Hey all,
So I've been spending A LOT of time in the DSP, changing settings, loading new versions from Hansshow, playing the knobs on the amp etc...I ended up doing something that Hansshow suggested to and it made a HUGE difference in bass from the system. I cut the purple wires and reversed them. At the moment it's 1000% better than it was before. My neighbour a ways away gave me the thumbs up haha.
I am about to go out for a long drive and won't be back until late tonight. I will work on a new video tomorrow that covers what I did and more information about the DSP. I don't know if I received a harness where things were incorrect or if that was by design. I don't know what the drawbacks are just yet as I haven't played around with it long enough, but from the hour I spent tinkering around I was much more satisfied. Almost too much bass! haha
Told you the polarity was reversed! You got it!
Is it the fix for reversed balance? Hansshow said ot’s notHey all,
How did your subwoofer sound before doing this? You’re saying you did improve the subwoofer a lot by flipping these purple wires? What’s the reason behind this?Is it the fix for reversed balance? Hansshow said ot’s not
